GR Yaris LSPI discussion
Onehp
Svveden
With the Motec I never go WOT under 2500rpm. Always always listen for knock.
For readers not familiar with why, it's called LSPI Low Speed Pre-Ignition and is an issue on all DI gasoline turbo cars, which is more or less all modern gasoline cars. Also very important to use the correct oil spec for this very reason.
Subaru engines seemed to suffer from it in particular LSPI).
Which is why it was baffling that so many Toyota dealers were servicing using the wrong oil back in the day. Under part throttle casual driving it’ll be fine but under load it’s a recipe for disaster.
Same with people running 95RON and saying “it drives just the same”.. it doesn’t at all. As I’ve alluded to earlier I’d rather have the car be mapped for a certain fuel than rely on electronics to (hopefully) pull timing before a massive knock event
At the risk of going further off topic it’s a feature of low capacity, high boost pressure GDI engies specifically. Subarus may suffer catastrophic knock but LSPI is when you have a lot of boost at low rpm which causes a chamber condition that can cause pre-combustion of the mixture. There was a new spec brought out as SN+ as an interim before SP was created which changed the additives in the oil to help mitigate pre-combustion but it can still happen with too much timing or boost spikes; sure I read it was about calcium content but don’t quote me on that
Knock in itself as a general issue is still the killer. But LSPI is a specific issue that you get with modern small engines that use a lot of boost pressure to make torque
At the risk of going further off topic it’s a feature of low capacity, high boost pressure GDI engies specifically. Subarus may suffer catastrophic knock but LSPI is when you have a lot of boost at low rpm which causes a chamber condition that can cause pre-combustion of the oil. There was a new spec brought out as SN+ as an interim before SP was created which changed the additives in the oil to remove the ones that were pre-combusting; sure I read it was about calcium content but don’t quote me on that
so just add G30 series and no LSPI issues?
I am very interested in it actually ( LSPI and Knock)
If you look at current designs and I am referring to capacity of around 1.5 to 2.0 the trend is under squared meaning the Stroke exceeds the Bore.
Subaru engines are stilled over squared looking at the 2.4 WRX.
I am thinking the smaller combustion chamber reduces the chance of LSPI and knock. I am not an engineer so I maybe completely off here.
Out of interest, with the Motec I have peak boost pressure ( around 23-24psi ) by 3000 rpm.
Sorry to get off track.
Moving discussion on LSPI here from the EcuTek thread.
LSPI is hard to understand, but theoretically more exposed cylinder wall is worse, so very long stroke and small bore is worse. But only one factor...
I agree: complex but interesting topic... kinda of important too 😅
Would be really good to gather all knowledgeable takes and experiences on LSPI, regarding:
-Bore/stroke ratios (not that we can do much about it..);
-Oil types, additives, standards, etc;
-Oil viscosity;
-Oil 'vapours' at combustion chamber;
-Fuel - eg. brands, old fuel, octane ratings, ethanol ratios
I'm running E30 in the belief that it's the best blend to avoid LSPI. But haven't gotten a hold of the research behind it.
And the correct oil spec of course.
I was also reading somewhere that smaller bore vs stroke lowers piston crown temps as well.
The piston crown transfer heat to the rings and then to the cylinder wall and then the cooling system.
Long stroke engines are more efficient for this reason iirc. But yeah it's complicated, the oil film on the cylinder walls might harness the "fuel" for the LSPI, but a hot spot nearby on the piston might spark it. Who knows...
Our engines have very good piston cooling otherwise with was it three oil jets cooling from below...
I think it’s important to isolate LSPI as a specific issue. Of course knock has been known about for decades and higher ethanol content, retarding timing etc all helps to mitigate it
LSPI seems to have come from OEMs making small capacity high boost pressure econobox engines and finding the calcium phosphate content of the existing oils prone to leading to pre-combustion at low rpm, hence the low speed part of LSPI.
High cylinder pressures and heat can ignite the oil, much like a diesel engine, which seems to be what causes the pre ignition. By lowering calcium phosphate content and adding magnesium phosphate this seems to mitigate it so it does seem to be oil related, this was the change from SN to SN+ and finally SP oils
The G16 has massive amounts of oil being sprayed at the cylinder walls and I’ve heard theories that the piston ring tolerances aren’t great which can lead to excessive oil getting into the chambers and causing these mega knock events that blow engines. Why cylinder 1 usually? Who knows. My theory is because it’s closer to the pump it’s spraying marginally more oil up there which could be the difference between bang and no bang.
Bad piston ring tolerances would lead to massive oil consumtion? Which doesn't seem to be a topic on these engines?
Of course piston rings and piston ring gaps are a compromise. Too large and you get oil consumption and perhaps LSPI. Too small and risk for scoring and ringland failures.
The oil from the cooling jets should be aimed at the bottom of the piston not the cylinder walls. No point spraying oil at the bore.
Why 3 cooling jets?. Me thinks the Toyota engineers are definitely concerned about high piston crown temps with this engine. There must be a number of reasons for the Youtube engine failures which seemed to be related to piston failure.
Sorry but I am of the option that Toyota make rather crappy engines ( there I said it) which is freaking amazing given their R&D department and all their motorsport experience like F1, World Rally, NASCAR and something else I am sure I have forgotten.
Then again their F1 engine was always crap :p
Would be nice to hear design story behind G16E-GTS - was Yamaha involved in the design etc.
The rally variants for Rally2 are built still in TGR WRT facility in Cologne, Germany.
According wikipedia,
"A de-stroked variation of the G16E-GTS engine with a displacement of 1.4 L (85.4 cu in), which is compatible with synthetic fuel, is used by the GR86 for the 2022 Super Taikyu series. The stroke was reduced from 89.7 mm (3.531 in) to 77 mm (3.031 in).[5]"
Didn't Yamaha design a cylinder head for Toy Ota way back when sometime. Geeze I feel old. Grumpy too:mad:
wow... never heard before about that de-stroked version, that would be a frenzy reving engine! (as long the valvetrain is kept in check). Always loved over-squared engines... wouldn't be something if some day Toyota comes with an inline-6 "G28E-GTS"
