GR Yaris ECU solution .... Is it real???
The laggy throttle response when reving the engine - only people who have driven 3 cylinder STs will understand how laggy the throttle response is and its terrible folks !
Only from the lowest revs and without load (revving up), I suspect it's because the engine probably runs only on port injection at that time (to keep intake valves clean)...
Ahh, okay. They were pushing nearly double the standard power though I guess!
Looked it up. 40kW up at the wheels, that is roughly 70hp up on the crank, can really see power drop past 5500rpm here (very early on in GRY development)
That said, MPS managed 400hp with stock valve train (with ethanol blend, maybe 370hp on 98), I've been speculating he managed to find a valve timing regime that works better?? Also minimum backpressure with a "motorsport" straight through exhaust (highly illegal in DE)
Bottom line: don't give your Yaris to just anyone in blind thrust for a remap.
I had the ST remapped with a 1200 rpm idle, which i would like the same for the Yaris, it gets it off the mark far quicker from idle.
Interesting how a few places have started that stage 1 / 300 bhp would be around £500, yet Litchfield are almost double that 🤔
I get that they have a GR but so do many other tuning companies who are offering cheaper options.
How will they know if it goes on track?
In Switzerland if you claim a warranty/insurance they’ll ask you some questions.
If you lie on purpose it‘s not only a wrongful claim, which can be denied, it‘s fraud which is a felony, not only an offense/misdoing and the consequences for that are quite serious.
And for an insurance company it‘s quite easy.
Their lawyer will write a letter to every trackday and racing organizers and demand a full list of their previous participants. Which they will provide.
If your name is on one of that lists, you‘re f*****.
That‘s what insurance companys do, and more, to check if any claim is correct.
All over the world, insurance companys about 20% of all the claims are fraud.
Which means, if they can detect half of them, they safe billions each year.
They won‘t do that for a 500£ claim.
But if you destroy your engine which will cost 10-20k, you can be sure, they‘ll spend some money to make sure your claim is correct.
How do i know that?
I work for one of the biggest insurance companys in Switzerland and i know that all of our „detectives“ are ex-Cops. 😅
It would be very difficult to claim I’d imagine as how could you guarantee and prove it was the map ?!
Mps also nice graphs with limited (clutch friendly) torqs 360hp/420Nm or thereabouts..
The same reason many purchased a Lichfield tuning box that was less refined than the DTUK box it was a duplicate of and spanked money on Nitrons before even driving their car.
The name has bragging rights for those that like to brag, so they’re happy to pay the premium.
I think you've hit the nail on the head 👍
As with anything like this, sit back & watch things unfold.
I wonder if Litchfield 310bhp map is on their car with the miltek exahust removed and running standard.
It will be interesting to see the results of such modification as they can now be "seen" by the ECU in the map
Instead of the ECU "fooled" by a piggy back box ?
I am hoping that a street legal setup of a exhaust with high flow cat and ECU remap can yield 310+ ?
But they had that because they raised the rev limit.
Keep the standard limit and you should have no trouble with float.
wrong....as I know it´s boost related, not rpm or power related. above 1.6 bar boost you could have problems. 1.6+ bar boost at 5500+ rpm to be exact.
So if you can achieve 210kw with 1.6 bar boost you are fine, if you push to 1.7 there might be problems with valve float. motive also achieved (after changing the springs) 2.0 bar at stock turbo. so stock turbo is a little strong beast...woohooo....
And for the remap discussion: Dont look at the price. ask what´s done. If one just raises boost to 1.6 or 1.7, that´s not a remap in my opinion......but that also gives some more hp as the tuning boxes do. if someone makes a complete map with adjusted ignition, angle and fuel tables, that´s much more work and even the better way to tune the engine. fuel consumtion should decreast too then. could be the same hp at the end, but with less boost ;) so better for the headgasket ;)
now as it is possible with stock ecu...ALWAYS ask for a complete remap at the dyno...custom for your car / mods. best choice
As far as I know, the 310 bhp is for a fully stock car. They said so on Instagram.
GR Yaris supports that out of the box. Just depress the clutch a bit while standing still, it revs up to around 1300/1400 rpms.
Yes i noticed that, but its too little too late, engine is already bogged down. Its ok if manuvering about in a parking space but, from lights and T junctions i need instant Hammer time !
