On the airbag side the Yaris is only two wires. A feed to an igniter and a return. The earth on the recaro wiring is not used. I have asked recaro dealers if they are polarity sensitive and they say “ask recaro” recaro say “ask your authorised recaro dealer”
. I do not believe they are and I have found this information regarding this.
Amanda. As far as the seat belt buckle is concerned it is normally closed and when the buckle is inserted it is open circuit. I have not been able to get a voltage reading from the circuit though, even with weight applied to the occupancy sensor. The system is working but I expected to see a switched 12v feed to it. In theory if the two wires were disconnected and isolated it would be an open circuit and the car would think the seat belt is done up. Not relevant for my set up but does this help?
