unrealpatrik
- Oct 7, 2022
- 115
- 269
So I have finally installed the Remark axle-back and decided to keep it!
It was quite loud, boomy and drony after the initial install. I went for a proper drive to heat up the system and refitted my K&N intake and re-tightened the axle-back. What a difference it made! I would recommend everyone to re-tighten everything up after few heat cycles.
Interior sound: The intake is louder than the exhaust in the interior. There is slight drone at 2K RPM and 4 - 4.3K RPM coming from the rear of the car. Nothing obnoxious honestly with the rear seats up, the drone can be mistaken for tire hum at higher speeds. Normal cruising around 2.5K - 4K RPM sounds almost stock. Tunnel pulls are addicting honestly. The intake and the axle-back create the perfect symphony for me.
Exterior sound: Hard to say as I am always in the driver's seat lol. The sound is deep and bassy. It's not raspy or hight pitched. The sound gets mixed up with casual aerodynamic/tire noise during normal cruising. Nothing obnoxious but obviously not OEM either. From the flyby clips you can first hear the intake and once the car passes by, the exhaust noise takes over. Cold starts are way better than I expected.
However, I don't daily drive and I park in a public garage where noise is not an issue, so take that into account. Important is that you can easily control the noise level with your throttle input. I am picky about car noise and this setup is absolutely fine for my taste. The car sounds like proper Subaru now.
