GR Yaris Corolla Oil Cooler
sixtentouge
I bought the HEL Setrab system from the UK but haven't installed it... My car's not used on track, and only on winding tarmac. Oil temp doesn't hit but maybe 115°C, so...
Has someone found the part number for the GR Corolla oil cooler? If so, is it bolt-on, like all the same hose placement, only a couple of plates larger?
I figure this would be the smarter move than to add another point of failure, plus adding the aftermarket cooler to the cooing stack pretty much puts the heat into the coolant anyway.
My oldest son is a tech for a large dealer here in Japan, but they can't just look up a part number. Need a VIN and some other numbers on an actual title...and I don't know any of the 500 people who got a Corolla here :)
they say GR Corolla would have larger heat exhanger but from the pictures it looks rather similar (for the size).
picture from the GRC forum from the other side. Wouldn't be the first time things get mixed up in press, could also be that GRC has a bigger radiator.
For the road use I'd say leave it as it is, especially if your oil temps stay sub 120'C.
Agree, no point going oil cooler if oil is 115°C which is near enough a perfect temperature. Hot enough to boil off moist and to reduce friction losses, but not so hot that there is risk for degradation.
I am no expert, but at which temp you’d start to think about additional cooling? If it matters: No track use in my case… Thanks!
I saw a Japanese video from a GR shop where they were discussing the differences between the two engines. The Corolla exchanger had two or three more rows. Unfortunately, that's where it ended, and no discussion on fitment.
Agree on the sub-120° statement.
Anyone know at which temperature a typical 0w20 respecting the current norms starts to actually "disintegrate"?
140 seems way too high for comfort but I'd like to know where the shear point lies because once you've reached that temperature you basically instantly need to change the oil.
An oil cooler seems to be a must for most of us but I've been told that installing one would void the engine warranty...
anyone knows the part nr. for the GR Corolla exchanger?
interesting question but is there a clear indicator for that disintegration in oil specs?
Just checked one oil type that is usable for GR in two different viscosity ratings.
5w30 viscosity in 150'C is 26% higher
0w20
Oil typeFlammpunkt ('C)Viskosität bei 150'C (mPa*s)
0w202482,69
5w302403,4
0w20
0w202482,69
5w302403,4
That's why I wanted to ask, given that this doesn't really seem to be something that is communicated by engine oil manufacturers (probably for good reason since you shouldn't really be running anywhere near that temperature really).
The fact that you can get your Oil temperature up to way over 120°C on the Yaris (with everything still being stock) does make me think though that the Oils are possibly actually still within their specification and that lubcrication could possibly still be fine at those temperatures. Or Toyota just didn't want to deal with a radiator based oil cooling solution.
I wouldn't be so concerned about oil being within specification above 120° but rather oil pressure at those temperatures.
0w20
0w202482,69
5w302403,4
and
at 100'C
0w20 8.93 vs
5w30 11.1 (24% higher)
at 40'C
0w20 50.5
5w30 65.6 (30% higher)
I asked Saito-San this very question when I met him at a meet and greet as he was having a look around my time attack GR Yaris and he said to use the official GR 0w20. Asked about 5w30 and he still said stick with the 0w20 even for track work.
Maybe it then cools down better. Im quite sure they have done their homework
I wouldn't speculate or put words in his mouth. Just sharing the information he gave to me. He did mention if I can get it to use the endurance or circuit stuff they sell in Japan but we can't get it here. I've taken it to Toyota NZ and they asked Toyota Japan and said it is for Japan Domestic Market only.
Regardless he wanted us to stick with 0w20. Make of that what you will. :)
GR Yaris oil cooler - 15710-18010
GR Corolla oil cooler - 15710-18020
If I'm not mistaken, the GRY from 2021-07-01 and the GRC engines use the same oil filter bracket - 15609-18011. Therefore, the oil cooler should fit, unless there's a difference in coolant hose diameter, but that's an easy fix ;)
Not cheap that GRC part, one source listed it for 1kUSD.
Technically its a water to oil heat exhanger, not cooler. if your radiator is the same it doesn't add much extra cooling, just grasps more heat to that water radiator. But could work for shorter runs.
Toyota refers to it as the 'Cooler Assy, Oil', I've used that naming . The GRY part costs 740€, so 1k$ is in the ballpark and most likely correct. It's definitely not cheap, and certainly not worth the expense.
Question is, is he giving your GR or the Bundaberg GB the thumbs up!?
