- Thread starter
- #41
So what do you propose for 10-20 persons custom suspension?Yes, No problem to configure your personal setup. This should be around 3k and can be made just one set for you. But if we want the stock setup for rear I thing it would be a problem - expensive for one set development. For me no need for thermal compensation but hi/lo speed is must have and seperate reservoirs are nice to have![]()
Edit: or no longer needed if staying coilover rear? We can discuss the merits of adjustable high speed compression. I suspect the seperate reservoirs are necessary for the HBS... Or maybe we should just start talking to Protlum to find a reasonable consumer spec ?
