GR86 New Toyota GR86 Front Lip / Splitter
look forward to it, which one did you go for?
always liked toms racing so went with the same for sides
look forward to seeing it, please keep me updated...
Would be interesting to see how it is too, will most likely go for a splitter, skirts and spoiler once I’ve got an exhaust
wont be fitted tomorrow but i'll do a side by side so at least your can see colour difference of the HTauts front splitter
here you go. But as a brief comparison the HTautos is slightly shinier as its plastic whereas the Maxton is supposed to be ABS plastic but its more like coated / painted MDF (more flexible). Unsure at this stage whether it'll be that noticable, esp as the sides arnt connected to the front so its not like its one long peice where you would notice the change in material.
@vinny85 Thanks for that, I don't think it will be noticeable as you say as on different panels, nice to see that they are pre-drilled. Worth the money? Look forward to seeing it installed.
I think so. Packaging was excellent so as long as the fitting goes well (it should be far easier than the front as its just align correctly and use the provided screws) then should be a good purchase. I have the TRD LOW LINE kit for my ST and has lasted 4 years (a few scuffs as i've hit bumps) but once it's bought and fitted it's one of those extra's you just forget about the cost.
Also if you did scuff it , you can always remove the HTAuto and replace with a new Maxton front splitter if you so wish.
Also have to remember that i think you are only going to notice the colour difference when it's been cleaned. As soon as you get road grime all over the car i'm pretty sure most of it is going to look pretty much the same.. i.e Muddy. (rather just get the whole car done than wait for HTAuto's to release theirs - which sounds like it's going to be a while - unless they speed production up now Maxton have released theirs - after all there isn't a continuous production of GR86'S ;) )
Looking forward to seeing what they look like fitted. Considering for my car too.
So managed to fit the sides and rear's today... looks real good!. I know a few were debating buying these if they had already purchased the HTAutos but no need to worry. You cant tell at all that the front is from a different supplier.
Some of the pre-drilled holes are in some strange places and possibly not the best. As you can see some are fine but others have to be pretty accurate. Also the screws aren't actually screwing into anything substantial so we decided to use red wall plugs (cut to length) to stop the screws falling out (point being if we manged to push a wall plug into the hole it just shows that there is absolutley nothing the screw is going to, well, screw into. And we used them in almost all the holes). The rears were a little awkward to fit but got there in the end but again you might need some more screws (i'll try and get a better pic tomorrow )
P.S NEWS5 gets you 5% off .
@vinny85 looks really good, seriously considering..... do you think that it would be possible to install just with a jack? Do the back bits screw or clip into the bumper?
could be possibe but it likely wont be easy. If your not too confident then might be better to wait to see if someone can sort with a jack. im luckily as i have a pit so made fitting so much easier!
Also the rears are screwed in.
@vinny85 I Bit the bullet and went for it, also with the addition of the rear diffuser.
thanks for image . yeh based on our experience with the sides / rears i bet it wasn't straight forward ! don't personally think this something i'll be fitting.. i quite like the rear as it is but maybe once i get bored i might go for it / another design.
