GR86 Thoughts on six months of GR86 ownership (Elise and NSX content)
RedCarsGoFaster
Devoted member
In the now distant pre-delivery days of December 2022 someone on here asked the question "Do you actually know what you're getting?", and I felt sufficiently intrigued by the question to register an account to give an answer – see link for reference.
Well, a year later I now have six months and 6000 miles of GR86 ownership behind me, and I feel I’m probably well equipped to reflect again on that question and my original answer.
The short answer is that the car has overwhelmingly lived up to my expectations for it. I might do some minor tweaking to one or two areas, but I’m very happy with the car I bought.
For the record, my frame of reference is that the last 12 years of my car history has included a Lotus Elise, a Honda NSX . . . and that’s it. I’m therefore approaching this from a slightly odd perspective, as the GR86 is the most practical, sensible, and definitely most modern vehicle I’ve owned.
I took delivery of my car in May this year, and immediately took it for a detail, PPF, and ceramic coating. In the two hours between leaving the dealership and arriving at the detailer a bird shat on the protective film on the bonnet, thus proving its value.
First things first, there are some modern car features which have transformed my motoring experience. Apple CarPlay is amazing. Modern headlights beat out incandescents hands-down, blind spot warning indicators and the reversing camera are extremely useful, keyless entry is a form of witchcraft that I still don’t entirely trust, and I haven’t owned a car with a trip computer since 2011, let alone one with a G-meter, external temperature sensor or tyre pressure sensors. Even just the big mirrors are a step up from what I’m used to. Heated seats, too!
It is (again, frame of reference) a remarkably practical car. Within a couple of weeks of getting the car I'd used it to go to the tip and pick up a desk from IKEA. I can also report that it will fit a pair of skis inside, and can be used to carry a full set of wheels and tyres for an NSX, though unfortunately not both at the same time.
The indicators are a non-issue. I don’t mind the engine noise speaker, either.
On more than one occasion I have found myself with a requirement to transport smart clothes that should really be hung up to avoid creasing (you can see where this is going). However, the 86 is still better than the Elise or the NSX in this regard, and I’ve found that hanging a coathanger from the back of the passenger seat headrest struts works plenty well enough for me.
My partner’s RX8, which is uncannily close to the GR86 in several ways, has a clever little handle inside the boot lid so you can close it without getting dirty fingers. The GR86 doesn’t. I need to buy and fit one of those little straps.
Fuel economy on a motorway is impressive. On my regular journeys I'm getting an average of 36ish mpg, admittedly with significant assistance from the 50 limits on the M42. Around town or on more interesting roads this drops to below 30mpg, but I’ll take that.
The big bugbear of the GR86 for me has been the throttle response. Initially I found the response frustratingly mushy, with a weird delay, especially around town. After a couple of thousand miles I tried the throttle pedal reset procedure and can report that this significantly improved my experience – perhaps mine just hadn’t been set up properly at the factory?
The throttle mapping, as others have commented, gives you a lot more result for a given input low down than it does up top. This is fine until you're gradually pushing the throttle down as you accelerate, and then find that beyond 60% pedal travel you really don't get a lot extra. I need to learn to drive around this, perhaps by driving in a more digital manner. (NB: do not drive an Elise this way)
Much has been made of the improved torque delivery of the FA24 compared to the FA20, but compared to the torque delivery of the 1ZZ in my Elise or the C30 in the NSX there is still a pause in the torque delivery in the midrange. There’s strong initial torque response (probably due to the throttle mapping), then a brief pause, and then the engine starts to really pull from 4500rpm onwards. Fine once you’re used to it, and the change in character as the engine races towards the red line is really quite exhilarating, but it took me a little while to learn that the torque curve on this car is not as linear as the other two.
I also find that the throttle pedal is positioned a little too far away from me. Not only is heel-and-toeing at road speeds a little challenging, but it’s quite a reach to the pedal, with the edge of the seat squab sometimes digging uncomfortably into the back of my knee as I stretch for it. I have a Verus pedal spacer coming and will report back on whether this improves matters.
I like the gearbox and the brakes. The steering has less feel than I'm used to, but there are very few cars that have steering feel like an Elise, and that level of feel is not desirable in all situations. I'm very happy with what Toyota have done with the steering for the role I want this car to fill.
The lack of body roll is startling, but perhaps not surprising when considering that the flat four engine probably drops the engine centre of gravity significantly when compared to the inline four of the Lotus or the V6 in the Honda, even taking into account those cars’ low rooflines.
The handling is very good, and the ride is surprisingly good also. Sometimes the rear seems to run out of travel and hop over sharp bumps in a way that the Lotus and Honda don’t, which I’m going to ponder over a little more and see if I can work out.
Occasionally traction is broken in unexpected circumstances, but I have yet to experience a significant deviation in yaw, either deliberately or accidentally. At some point I need to go do a drift day to find out what that would be like.
There seems to be a full-on 86 mafia at my workplace, and I think there must be half a dozen different GT86s that I see in the car park on a regular basis. Shameful admission that it might be, I sometimes prefer the exterior styling of the earlier car - it seems a lot lighter and sharper, almost as though the GR86 has been inflated to the degree where it's lost the haunches. The interior of the GR86 is worlds better, though, and in general I tend to spend slightly more time sitting inside my car than admiring it from a deckchair at car shows. No judgement if that's your thing. OK, a bit of judgement.
My car has had the ducktail spoiler fitted, and that was the correct call.
To my regret I've spent far more time on motorways in my car than on B-roads, but the Christmas break afforded an opportunity to really exercise the car for a significant distance cross-country and up through Wales. It's all too easy to forget when cruising in a straight line how well the car meets the sports car brief, but given a clear stretch of mountain road and the opportunity to exercise engine and chassis, you soon remember. It's bloody brilliant 😀
Things I miss when driving the 86 compared to the Elise or the NSX . . .
The Elise has so much feel and immediacy of response that it’s possible to make driving around town a delicious sensory experience. Approach a roundabout, blip the throttle for a perfectly matched change down to third, pick your line, turn in, feel the steering load build up as you sense a change in the surface of the tarmac through the wheel, blend in throttle as you relax steering away from the apex, snick another gear . . . and at no point have you exceeded 30mph. Mix in the open top on a summer evening and you have an almost unmatched driving experience. A Caterham or an Atom is even more pure, but it's nice to be able to keep the weather off if you're caught out in it.
The 86 trades some of that sharpness and experience for increased comfort and an ability to deal with adverse conditions, in addition to being, well, a car that you can use to transport people and things . . .
The Honda has an absolutely fabulous engine and gearbox, which probably won’t come as a surprise to most. However, the thing I particularly appreciate (and which is usually overlooked) is the quite spectacular visibility. Apparently the chief designer sat in an F16 once and it left such an impression that he decided to try and make a car with that level of visibility, and oh boy, can you tell when you sit in an NSX. The dashboard and nose have been quite deliberately pushed as low as possible so that it feels like you can see the road rushing by just in front of your toes, the A-pillars are thinner than a very thin thing (just don’t ask about crash tests), and with that bubble of glass over the engine bay the only other interruptions to your sightline are the headrests and B-pillars. It’s very hard to sell that in a brochure or brag about it in a pub, it’s particularly hard to engineer a car in such a way as to really maximise visibility, and so very few manufacturers make the effort. Indeed I suspect many go for quite the opposite effect, building cars with high waistlines and dashboards so that you feel cocooned, with the added bonus of contributing to that rule of thirds thing where styling dictates that the glass is restricted to a little sliver around the top of the car. The way Honda designed the NSX for visibility probably only matters to obsessive nerds (guilty), and the only manufacturer that still makes an effort to do visibility like this is (quite fittingly) McLaren. Gordon Murray daily drove an NSX while he was designing the McLaren F1, and I’m convinced that the introduction of that low dash and deep screen into McLaren’s design DNA is not a coincidence. That visibility, combined with the fact that the NSX is actually quite narrow, makes it a surprisingly friendly thing to pilot around.
I also get a particular kick out of the engineering that went into the NSX. An all-aluminium monocoque, the 8300rpm red line enabled by titanium conrods, the Monel key, the gloriously elegant forged aluminium double wishbones . . . there was a lot of high engineering lavished on that car just because they could. You don't really get a lot of that these days, and where you do, the price point is well outside my budget.
Sadly the NSX has now been sold (not enough parking spaces and just a little too much maintenance downtime), though I miss VTEC, that intake bark and the gearshift every day. I don't miss troubleshooting problems, sourcing parts, trekking miles to go visit an independent garage I trust enough to work on it, and the accompanying bills. Hopefully the effort I've put in will pay off for the next owner, but it can be hard work trying to keep up with the specific problems of an ageing and pretty niche vehicle, particularly if you actually want to put miles on the bloody thing.
The Elise will be staying for as long as I can reasonably hold on to it. I suspect that one day the 86 will have to go as well to be replaced by something electric, but if I can hold onto the Elise for early morning drives then I’ll keep doing so even if I have to feed it £5/litre artisanal free-range carbon-captured eco-fuel.
To conclude this ramble, does the GR86 live up to the hopes and expectations that I had for it when I placed my order? Yes, yes it does. It’s sensible, comfortable, and practical every day, and on a Welsh B-road gets surprisingly close to the level of enjoyment that I get from my Elise. Great buy, great job Toyota, pats on the back all round.
Now, about that boot handle . . .
Great post @RedCarsGoFaster
No reason why we can't have a section in the GR86 forum for Owners Reviews, instead of leaving it in General - ideally needs others to do a write-up every so often.
No need to comment and interrupt the thread, so if you would like a dedicated section then simply like this post.
Edit:
Owners Reviews section is now available for GR86 owners here.
Eloquently written and a joy to read.
Great review.
I have an Elise and a GR Yaris, both are red - so yes the fastest ones 😀
I did a week long trip to and around Scotland (much of NC500) in September in the Yaris and spent quite a bit of time following a GR86. It went very well, surprised me on occasions both in terms of speed and the way it handled the road, yes there was a bit more rear end movement and slip than in the Yaris but it managed to look quite composed with it. It was also way better on fuel but I guess the 4wd on the Yaris accounts for a fair bit of its extra thirst.
If I didn’t have the Yaris I think I’d probably have bought a GR86.
The Elise and the GR are so very different in many ways but both provide a huge amount of driving pleasure.
Brilliant write up, thank you for taking the time. I had one on order but cancelled back in Nov as couldn't really justify it in addition to my current cars. I see there are a number still available at dealers though so am having second thoughts now.
As others have said this is a great read, it justified reading on my iPad rather than a small phone screen. I’m wondering about having a test drive of a GR86 if I can find a (presumably) used one at a dealer - it looks brill so good to find out what they’re like longer term.
Thanks for posting (visiting from the Yaris part of the forum as turns out I’d accidentally hidden the GR86 part last year and didn’t undo it - did wonder where the content had gone).
The throttle spacer from Verus is a great upgrade, the throttle response can be made slightly better with intake hose (using Greddy one), filter (AEM) and exhaust but it's still a far cry from a cable throttle from back in the days
Other than that, please do check the alignment as they are all over the place from factory. And depends on your taste, the front will need a lot of camber if driven hard (0 from factory on my car)
The GR86 is my daily car, the relatively "dull but refined" response compared to the noisy and hyperactive S660 is a plus for me. It's just about right after a few choice mods!
Enjoyed the read, thanks for taking the time to write all of that up!
I didn’t know there was a throttle pedal reset process, I’ve learnt something new and will have to try it.
The NSX is gorgeous - a car I’ve sadly well and truly missed the boat on price wise, and one I’ve always wanted to at least drive, if not own. Every time I see one at an event, I’m drawn to it.
Another current Elise owner here too, there’s a pattern emerging…!
Another old Elise (S2 111S) owner here.
I bought the GR86 as a daily with a bit of poke and it fulfills that perfectly.
I do miss the rawness of the Elise, but not the lack of practicality (it was also a daily for many years).
