Itcaptainslow
- Sep 4, 2023
- 379
- 425
What are people running, out of interest? And why?
Exactly this for me too.I settled on 32 (2.2) all round on an entirely subjective basis in that I prefer the way it rides, streets and handles that way.
It feels more supple and compliant than the standard pressures.
Given that I never drive the car anywhere near fully loaded I don't see the need to use the standard pressures which will have been decided on for safety under the most extreme fully loaded conditions.
I've had a look but didn't find any way to change it, no. Suspect that maybe there's a regional setting somewhere that sets it.Is there anyway to change the readout to PSI at all? Maybe in techstream? I only use bar as a boost measure.
Would be interested to know if this helped with tyre noiseI've just dropped mine to 32psi this evening.. Just to see what the tyre noise is like
If it's no different that it was at 35psi I might go back up
I think the tyre noise is improved.. but it’s marginalWould be interested to know if this helped with tyre noise
It shouldn't do if you reset the TPMS after setting the desired presure.Thread resurrection time!
Having changed out the OEM (7.5") rims for 8" ones and swapped the 215s for 225s, I've been wondering what would be the best inflation pressures on the GR86? It seems to be quite a subjective matter, but the general consensus is wider tyres=less pressure. Today has seen me throwing numbers into an online Tyre Data Calculator to see what it came up with. It would seem that for better comfort I should probably go for anywhere between 32-34 psi (2.2-2.3 bar), which is between 1-2% less than OEM. Anybody else played with this calculator? My issue is that any time that I set a lower pressure than the recommended 35psi, the bloody dashboard warning comes on all the time telling me I have 'low pressure' ...![]()
