I managed to take the car for a little squirt in the back roads tonight on “private land” and found super interesting results using guesstimate. I basically recorded the boost gauge while WOT and slowed down frame by frame to see what rpm I was at before boost came on. Don’t mind sharing video if it brings any insight
When WOT in 3rd from 1750rpm, I see the orange dial hit 1 bar at 4000rpm and continues to climb to what seems like 1.2bar and holds that until redline.
1st run WOT in 2nd from 1500rpm - I see the orange dial hit 1 bar at 3100rpm. It only changes to 1.1-1.2bar after it’s hit 5250rpm
2nd run WOT in 2nd from 2100rpm - I don’t see the orange dial hit 1 bar until it’s at 5550rpm (this is what I experience but usually worse as I never see the orange dial/never hit 1bar )
3rd run WOT in 2nd from 1750-1950rpm - I see orange dial hit 1 bar at 3100rpm. I don’t hit 1.2 bar until around 5100rpm.
Unofficial as I didn’t record this, but as I was going home and did another second gear run, it felt ridiculous. I think from memory I hit 1bar at 3000rpm and hit 1.2bar at 4000rpm and that was the fastest it’s felt all night (+ fastest it’s felt in weeks)
As you can see, 1st and 3rd run in 2nd gear were the best and the first time in a long time I’ve seen and felt the ‘boost’ kick in. Especially the run on the way back home.
I didn’t even try first gear as the few times I did I still had the issue of it only going to 0.8bar. I’ve also noticed 9.5/10 times if I shift from 1st to 2nd WOT I don’t see peak boost of 1.1-1.2bar. Only when I’m already in 2nd gear at a low rpm will I feel boost it seems, but this was just one night of ‘testing’.
Wouldn’t know how to present these findings to Toyota though
