I have a problem.
I never thought id have to come clean on the forum but it looks like Im going to have to say it. After lots of ‘no its ok, i’m fine. It’s fine... Really...’ style comments I have to talk like im at AA.... Er, Yaris Anonymous?
Anyway, I’ve been getting a crick neck... In our house its being called ‘Yaris Neck’... Oh no! Yes the Yaris is to blame... Damn. But, im hooked Dr... I love the thing so much!
Yeah, I have come to the conclusion that the ducking and diving around the oversize OEM mirror is causing me an issue. While it’s not a huge problem to deal with when Im driving as I don’t notice Im bobbing around like Flat Eric.
That action it appears is aggravating an old motorcycling injury. It hurts 90+% of my day, is annoying when I try to sleep so I needed to fix it.
I decided a while back that Toyota’s choice of mirror for this car was at best a cheap and penny pinching move. My feeling is that they literally picked the first one up they found in the parts bin during development and said ‘
yep that will do. It’s a rally car and people will ditch em anyway’ or perhaps they simply planned to come back and find something better suited and then forgot as they just got used to what they had fitted or time ran out at the end of the project... It wouldn’t be the first time that happened. Lol.
Of course we all know the mirror isnt perfect, you only need one article or youtube ‘influenza’ (sic) to tell you how hard it is to see out of our beloved cars lol. And yes, I’d worried, like so many of us that the mirror was the size of something out of a truck mirror and that looking across the bonnet would be nigh on impossible etc, but after the first few mins of ownership I found that instead I simply got used to the mirror being there in the same way you get used to the seat height and other little GRY foibles, like the cabin noise etc. lol
Anyway, what I hadnt considered was that longer term this moving my head around, ducking and diving, to get a view so I don’t mow down errant cyclists and pedestrians in our fair city might inflame an injury on an already somewhat second hand part of my aging body... Im not exactly ancient, but... I am rather ‘second hand’ now
The problems with the OEM unit are well covered in the threads, but for completeness I’ll go over them from my perspective:
1 – its too wide. It only needs to be the size of the rear window, which is tiny.
2 – it hangs down too far. This is a function of where the arm on the mirror is located and amount of adjustment in the bracket. It can be improved with filing a groove to allow more movement or fitting of a circa £50 riser which a few people sell.
The problem with only focusing on the adjustment issue is one of angles. When improving forwards vision the most obvious fix is to move the mirror upwards to sit closer to the ceiling of the car. All good for looking forwards as you’ve more chance of looking under it now, but less good for reward vision when you bear in mind the roofline of the GRY has been lowered at the back 10cm thanks to Mr Makkinen’s desire to improve aerodynamics – a fact proudly explained on the launch of these cars – which only gives us a tiny letterbox to see out of.
This lower rear roof means raising the mirror acerbates the already problematic issue in the GRY of how much you can see out the back window due to the glass being lower than the mirror. This means that the higher the rear view mirror is placed the more you look ‘down’ when you look out through the window, this angle forces the driver’s view downwards and not outwards; seeing less distance behind the car. This is easily seen in the GRY when you use the OEM mirror and drive down a hill, when you reach the bottom you cannot see any of the cars on the road behind as the road is above the angle that the mirror can see.
Thus the better approach is to have a physically smaller (less height and less wide) mirror than what comes with the car since we only need to see out though the back glass, not the interior of the car. If at the same time we can find a mirror that has the option to adjust higher into the ceiling then that would perhaps help as well depending on the length of the ‘trunk’ of your body. This gives you the height for your eyes above the seat, legs are not a factor here which is why some tall people can fit fine in a GRY as they have a shorter ‘trunk’.
I’d read around the threads on the forums and found that guys had settled on some GM mirrors, mostly from the Astra models, but fitted to plenty of cars of the era being a generic Gentex supplied unit. I assume Gentex is part of General Motors given the first letters of its name...
After looking at a lot of mirrors I settled on a unit from a Vauxhall Insignia as it had a camera mounted to it. These can be had cheaply and the camera is easily removed allowing its bracket to be repurposed for a dash cam. The info on this unit came from Krusty in this thread:
https://www.gr-yaris.co.uk/forum/th...cal-faults-fitting-smaller-mirror.2829/page-4
I did some ebay and google searches and found lots of them. Even brand new ones can be had and that they were reasonably priced if I didn’t want an old sun damaged and smoked over unit. Cool.
I also noticed that Krusty hadnt come back with updated info so dropped him a PM to see if he had anything to add and what he told me changed my tack pretty quickly.
Sadly the GM mirror he bought didn’t function and that he sought out a more OEM solution, settling on the previous generation Yaris mirror...
{needle hastily removed from the vinyl soundtrack running in the background!}
Er.... Hold on...! Did you just say there was a Yaris mirror I could use?
Yep!
Krusty told me there was a previous generation mirror with auto darkening feature for the Yaris? It was used on the higher spec cars including the GRMN. I’d totally missed the thread where he’d mentioned it on this forum as well. Here it is for completeness:
https://www.gr-zoo.com/threads/replacement-rearview-mirror.138/#post-1002
The beauty of this unit is also that with the end of the bracket chopped off it is essentially plug and play, ie you simply plug the mirror’s plug into the connector vacated by the OEM mirror’s as the new and old mirrors have the same plugs and the pins are in the same places to use the +12v and ground from the car. I don’t mind de-pinning and fitted another connector like you do with the GM units, but why not have something easy for once.
Here it is when it landed today all the way from Lithuania:
Comparison with the ORM GRY unit. It is actually smaller than it looks in this pic weirdly.
So, let’s get started....
Whipping the old mirror off was easy, its covered in lots of places online, but for complteness:
1, Push the whole mirror surround forwards
2, Unclip the front section – small screwdriver in the tangs – and remove both pieces from around the dangling mirror
3, Unclip the old mirror connector (push down and pull) - Remember to catch the mirror as it falls...
4, Unclip loom connector from the bracket - push clip and slide - so its now free
I wish I could say step 5 was fit the new mirror with the line ‘reassembly is the reverse of removal’ in classis Haynes style... But it isnt of course...
5, Firstly look at both mirrors and gently cut off the bit of bracket not needed. This is simple to do with hand tools or a Dremel, just don’t cut the cable or the connector lol.
(Also consider covering the mirror so bits of alloy don’t get all over it, in it etc)
6, Then undo the white wire’s clip from it.
7, Clean up the cut part so it apes the original’s short rounded end. I also found making more room on the right side of the bracket where the wire would need to go helped so it wasn’t stressed due to its length. Make sure the edges are smooth so you don’t cut the cable with the vibrations over the next 100,000 kms...
8, A bit more cutting - As I say, sadly the new mirror has a short wire and meant mine was quite tight on the car’s connections until it was all fitted. This meant it was always going to be a struggle to get everything back into place. In the end I realised I needed to remove two of the four interior ‘wall’ sections on the inside of the large cover, these are the ones in a semi circle right behind the mirror bracket. I took the right hand side ones as that’s where my mirror connector was fouling the cover.
9, I then clipped the mirror connectors together and slid the big cover on while it dangled.
10, Then fiddle and mess with the mirror to get it on the bracket until it was fully seated and would slide fully forward. This was not easy due to the short wire and thus the connector being in the way until its all in place. If it wont slide fully forward its not correctly fitted, its not sitting flat enough at the back to start the two parts to meet initially. Mess with it until your arms scream and then after a rest have another go lol.
11, Finally, do up the Torx screw and clip the little front cover back into place.
12, Switch car on and press ‘Auto’ and you should see the light go on and off with presses. Now wait until night to check the dimming works but there is no reason why it shouldn’t really if the light comes on.
So what do I think? Well its smaller and higher up. I defo have more room to see around the unit so that is good. I do need to mess with it to get as much view out the back, but its in and it works.
One nice thing is that while its a smaller mirror that looks just like the GRY’s original unit just scaled down is that its also all OEM Toyota. I doubt any toyota tech is going to notice you’ve swapped this which is easier on any warranty claim further down the track. Toyota Aus are demons when it comes to denying warranty sadly so its always better to hide mods.
So... What does interest me is why that Toyota decided to ignore the previous model Yaris mirror which was a much better physical fit to the car than the one they used. A look at the parts book suggests that the D080 mirror is now NLA, so perhaps that is the issue.
Of course it could well be they originally used the 080 version on the development cars so no one commented on this problem. After all it was fitted to the previous GRMN Yaris so would have been an obvious choice. By the time it came for production they found it was NLA and since they werent going to buy enough to get them at the right price, they instead grabbed the new version and used its similar, but slightly different fitting... The fact it was larger didn’t bother the accountants any; its not like they’d even seen a GRY at that point, being only tasked to sharpen their pencils.
It could be that the older mirror’s sensors arent as good as the new ones, time and technology wait for no man as we know, or it could be that the parts for the old unit are just not available anymore. Chip issues anyone? Hmm...
All this said, and it has been quite a lot or words for a part of a car that no one ever gave 2 hoots about and simply ‘used’ without thinking.
Will it fix my neck? Let’s hope so... I had an Audi A3 with Sports seats once, they were poorly designed and ruined mine and my wife’s backs and it had to go, we were not alone and a few other people I knew with those cars cut them loose as well. Let’s hope I don’t have to go that route with this car. Since when did cars hurt us? I guess when we started to get old... Sigh...
I’ll report back, but for now I’ll keep attending the Yaris Anonymous program and follow the steps to enlightenment... Thank god I don’t have to go round and start apologising to people Ive beat at the traffic lights or passed on a sweeping B road... YA has no Steps 8 and 9, phew!
