More open duct will increase intake noise slightly. as it doens't have any sound deadening materials and more open design etc.Are there any dyno stats on it / any gains? I take it that with it being a duct, rather than an intake, that there is no additional noise with it? I have seen some similar designed non carbon ones that I suspect will do a similar job for less money. This duct is slightly more expensive than the MST intake (which I appreciate isn't carbon) but the MST has proven gains and sounds good. I guess it depends on what you want![]()
Oh, Forge seems to answer that already on their site:Log IAT before and after on, say, a few 3rd gear pulls, and we'll soon enough see the difference
How does 7 degrees difference on track translate into performance gains, any idea? Just to balance the £399 for what you get in return…Oh, Forge seems to answer that already on their site:
"Data was collated and logged live by a passenger on a track day running in conjunction with an aftermarket intercooler on a 5 lap open pit session back to back against the stock inlet scoop (another 5 lap session). Inlet air temps had been reduced from 42°C to between 35 and 36°C. We even saw temperatures of up to 45°C on the stock duct. Fluctuation between temperatures on the stock inlet duct were greatly improved when air was fed to the secondary inlet scoop via the composite Forge Motorsport inlet feed.
Well an IC drop mainfold intake temps about 10 degrees and they cost at least double. Now manifold and intake temps are not the same, but usually the IC is about delta and if you can drop 7 degrees on inlet, that should at least in part translate to reducing manifold temps, that is what the engine actually ingests. Like an IC, it's more about keeping the performance in hotter weather rather then gaining in absolute terms (although there is a power gain, just not massive).How does 7 degrees difference on track translate into performance gains, any idea? Just to balance the £399 for what you get in return…
After seeing graphics of a stock car yesterday, with and without Eventuri, I know where I’m NOT spending any money. 8-9 hp max delta. Not worth it in my opinion.
Do you think £399 is worth it for the looks or would it be worth buying a full system ? I am not keen on the sounds of eventuri whoosh sounds but want the potential performance gains. Any advice?I've fitted one - simply because I like the looks, bit of a fiddle but easy enough and only a 20-minute job. Can't say I have noticed much difference in sound but it looks great.
Intake does two things (if good):Any advice?
I got it with a bit off, at 399 it’s the usual gr tax, I think they are expensive but was happy to pay for it as I liked how it looked. If it improves the performance then that’s an added bonus - I didn’t buy it expecting any gains.How does 7 degrees difference on track translate into performance gains, any idea? Just to balance the £399 for what you get in return…
What does it drive like now with it fitted?I've fitted one - simply because I like the looks, bit of a fiddle but easy enough and only a 20-minute job. Can't say I have noticed much difference in sound but it looks great.
