50,000km service today at 25,000km actual. All good except they cross rotated the tyres. Wheels off this weekend... need cleaning anyway.
Cross rotation is correct is it not?50,000km service today at 25,000km actual. All good except they cross rotated the tyres. Wheels off this weekend... need cleaning anyway.
I don't. Just front to back.Cross rotation is correct is it not?
All tyre manufacturers recommend a cross pattern for 4wd vehicles.I don't. Just front to back.
Don't know the case here, but generally this doesn't work for directional tyres, only for asymmetrical ones.All tyre manufacturers recommend a cross pattern for 4wd vehicles.
And this is from the manual.Don't know the case here, but generally this doesn't work for directional tyres, only for asymmetrical ones.
Yeah, but it's not "all... 4wd" then is it. Anyway, I think "Humpty" kkows what he's doing.And this is from the manual.
I didn’t put all 4wd that’s just some selective quoting on your part. I just didn’t put there was an exception to the rule.Yeah, but it's not "all... 4wd" then is it. Anyway, I think "Humpty" kkows what he's doing.
And yes, generally most people don't rotate often enough, ending up with a terrible mix of worn and part word tyres of different model, budget, make and sometimes even tyre type and size.
Yes.maybe this is explained in the Users Manual (I just don't recall seeing it)... so I'll ask:
Upon tyres rotation, there's a need to reset the TPM sensors - in order to allocate the right car corner position? Cheers
Uhm maybe a dump question, but how do the sensors know their position on the car?Yes.
They have serial numbers and are programmed in at their correct position. So if you swap the wheels and tyres around they will be reporting the wrong tyre.Uhm maybe a dump question, but how do the sensors know their position on the car?
I'm tyred of this tread, so do we just do front to back or front to opposite back. Are we car drivers or line dancers.Easy to relocate - takes maybe 5min from car to figure where each sensor is
So preconfigured . understood. Thanks.They have serial numbers and are programmed in at their correct position. So if you swap the wheels and tyres around they will be reporting the wrong tyre.
Ulter exhausts... well. I know them from some NC and NB MX5s. They may sound okay ish. But the stock exhaust should be from better quality and have better flow. I personally would not waste money on them if you have the stock one or an other aftermarket exhaust.Ulter
Not yet done today, but very close on being sucked in my next rabbit hole eyes wide open (or shut hoping for the best).
Having owned (counting fingers).... about 13 different aftermarket exhaust configurations on 3 cars (and another 3 on 3 others not owned long) , I think I've found one to take the plunge on this one when browsing some german pages.
- It's ECE approved so should be reasonably quiet
- it costs less then half then any other exhaust anywhere near that sound level I'm looking for (backbox delete single exit doesn't count) so not spending silly amounts on something I don't see and will deteriorate quickly anyway with our salty winter roads - and cannot be pretected as rest of underside)
- from the single(!) soundclip I could find, I has a nice distinctive rolling r sound in higher revs
- European made
- Quality is a questionmark but can't be that bad and as point two perhaps overrated?
- So unless someone has horror stories with this manufacturer (let me know, search turned out clean) I'm very close to enter that rabbithole... And probably just hop out if I don't like it.
