GR Yaris Trickle charge question
Jip
Devoted member
North west
Hi folks, my first ( possibly daft ) question on the new Fourm.
What output do normal trickle chargers give?
I have installed one ( not mine ) I borrowed it. Has an output of 5.8 amps.
Perhaps more relevant is the capacity of the charger you are using, what is it rated for? If it's reading 5.8amps, it's probably rated for up to 180ah.
CTEK chargers are very good (y)
Reactions: Jip
The answer is, it depends!
Not helpful I know, however a 5.8 Amp charger is easily capable of charging the GR battery, what is in question is what sort of charger is it?
A "Smart" charger (Optimate, Ctek, etc) is designed to be largely plug in, connect up and leave it alone. A fit battery can be left on charge indefinitely on a quality smart charger, that's what they were designed for.
On the other hand an old fashioned charger with an ammeter on the front needs to be kept an eye on, particularly if it's able to deliver high current!
Even a 5.8Amp one of these needs to be disconnected after the battery has had time to charge (VERY approximately 16hrs) or it will overcharge the battery. And I would disconnect the battery from the car before use too!
I've been using an Optimate on bike batteries for decades and now a Ctek 5Amp on the GR, my older chargers haven't been seen for years ;-)
Reactions: Jip
What type of battery is in our GRY. Is it an AGM or a standard battery as I don't see "AGM" on it?
Reactions: Jip
standard lead acid....nothing to say its agm and thats how i have my charger set up for "normal" l/a battery
Thanks for that. I have the older CTEK 5.0 charger with the car and then snow flake mode - no AGM mode and I plan to use the standard car mode maybe every couple of months for sulphur cleaning and general top up when it has been stood for a couple of weeks.
Cheers.
Reactions: Jip
Cheers.
I leave mine connected whenever the car isn't in use. My RS has been connected since late October last year never had an issue.
Out of interest what CTek charger would people reccomend. Considering purchasing one as going to be away for a bit with work and don’t want to get home to find a flat battery.
Reactions: Jip
When the price of petrol hits £10 or even £15 per gallon for a while more cars will be placed on the charger as they will be used less. It was predicted today that £2 per litre will come within a few weeks. I have noticed I am using mine just once a week at the moment as I use the little Mii as that gets 50+ mpg and I don't go on many drives just for the fun of it. Hope it all gets back to normal soon for those families up against it at the moment.
I wonder if someone can help. I have a CTEK 5.0 charger - what mode should I be charging the GR battery - Normal or AGM?
Mine is about 6 years old and doesn't have the AGM mode. It has the snowflake. Someone said here or on the other site our battery is a normal battery and not AGM. Mine is currently on the CTEK 5.0 using the normal mode. I bought the comfort connector with the in-line fuse and traffic lights and fixed that to the + terminal in the engine bay and a bolt on the bodywork for negative. Green light flashing and number 7 iluminated on the charger and has been like that for two weeks. I assume number 8 comes on when trickling and not on all of the time. I intend to use this all of the time now and just unplug it once or twice a week when I use it as my little city car has become my main car and am very thankfull I have it right now.
I have a CTEK keeping my modern classic's battery and tracker battery in tip top condition. I cannot fault it. once first attached it will go through a checking / conditioning process. As each stage has been completed a green LED will appear, so if all green lights appear you have a good battery and the charger then monitors the amps and will only kick in when required
Thanks, yes on the other GR forum, they also mentioned to use Normal mode, so I'll go with that. Hopefully there weren't be any issues! 😬
Bit of a bump for the thread. I just got my GR Yaris and won't be using it daily. I bought a CTEK 5.0 charger and was wondering how I should connect it to the car.
I'm thinking to connect the small leads directly to the battery (without disconnecting the battery from the car) in the boot and use the quick connect/disconnect whenever I use the car. Am I right in doing so?
