GR86 Do you set the rev beep to sound?
Do you set the rev warning beep to sound?
  • Turned it Off
    Votes: 7 25.9%
  • 7400RPM at Redline
    Votes: 5 18.5%
  • 6500RPM
    Votes: 5 18.5%
  • 4000RPM still even after 1000 miles!
    Votes: 1 3.7%
  • Other RPM
    Votes: 3 11.1%
  • 7000RPM
    Votes: 6 22.2%
  • Total voters
    27
grzoostuff
UK North East
For those with run in engines after 1k, do you still have the engine beep sound on at certain rpm or turn it off completely?
Never worked out how to turn it on in the first place 🤷‍♂️
Think I set it to 7k
If you scroll through the vehicle settings on the dash you should find it, can't remember what it's called, but it is there somewhere.
I just found it annoying so turned the beep off.
I set the flashing rev counter to 6800rpm so I change gear as soon as it starts flashing.
I've turned it off completely, but it makes sense to have it set around 7k, before you hit the limiter.
I tried it at 7.2k but I quickly adjusted to 7k to allow a bit of leeway before - there's no other way to describe it - frankly walloping into that really rather aggressive limiter.
I've encountered the limiter once, and I never want to again thank you.
To be honest, I rarely get near the warning anyway. Tend to find myself shifting at 5-6k when out having fun.
I hit the limiter once in my GT86, mid overtake, I think it's basically a fuel cut. It was like throwing an anchor out the window. Assume it's the same in this car. If you have the car remapped it can be changed to a soft limiter though (so it will just bounce off the limiter repeatedly).
Yes I too mostly change up around 6k generally.
It's pleasing how, when compared with the GT86, there's so much more mid-range grunt to allow for this, whilst at the same time being far more enjoyable to rev up to 7k+ (with the caveat of the rather abrupt limiter).
And the engine is getting nicer with each and every mile.
3.7k! Just 200 miles'ish on the clock so far. Need to decide whether to increase that a bit, and when.
I think it feels geared really nicely when changing up around 6k
Turned it off recently with new exhaust, but set to flash yellow at 7000 rpm
6k for me, save the engine and gearbox a little on track days.
