Think I've found my first issue with the car, but could I ask people to test and see if they have the same? Just to rule out it being some bizarre feature.
Essentially, it's that the one touch UP feature (only) requires two touches to work on the driver's side.
- Pull the drivers window switch up so it clicks and release immediately...window goes up but stops as soon as you release the switch.
- Repeat the above again....window rolls all the way up as normal.
Only happens on the driver's window, and only going up from the fully down position. Pressing one touch down works first time every time. And passenger window works exactly as you'd expect....one touch works first time, both up and down.
Thinking about it, this has been like this since collecting the car. Several times I've reached down and pulled both switches fully to roll both open windows up, and found the driver's window never does. But as it always worked when I did it a second time, so I assumed it was just me never pulling the switch quite enough that it would click to one-touch. But it happened this morning so I stopped to test it and can repeat it.
Irritating that I'm going to probably have to go back to the dealer again :/
EDIT: Took a video. It seems to be that the problem only occurs when the window is fully down. If I roll the window halfway up, then one-touch from there it's fine. If I roll it nearly all the way down, then try and one-touch up from there, also fine. If I roll it completely down, then one-touch up - stops as soon as I release my finger.
