Where I thought I have fixed most of it with 1 degree extra camber up front, the understeer really shows mid corner when the suspension is loaded up on it's side. The car won't really respond to throttle lift or any weight transfer still.
Any suggestion other than driving around it? This have to be the most understeery car I have owned... With 1 degree, it's fine on short corners and transisitions but when the suspension is loaded up in a longer constant radius corner, all I got is push.
Gonna try a few things before I dismiss the car or go full coilovers
- -2.5 degree front camber (proably will do ASAP, hopefully that's the cure)
- Toe out front (daily driver with a lot of miles, I would rather not)
- Reduce rear grip by adjusting tyre pressure (Don't actaually want to reduce grip anywhere, I want traction going out of corners still)
