GR86 GR86 understeer mid corner
Stardus.
Where I thought I have fixed most of it with 1 degree extra camber up front, the understeer really shows mid corner when the suspension is loaded up on it's side. The car won't really respond to throttle lift or any weight transfer still.
Any suggestion other than driving around it? This have to be the most understeery car I have owned... With 1 degree, it's fine on short corners and transisitions but when the suspension is loaded up in a longer constant radius corner, all I got is push.
Gonna try a few things before I dismiss the car or go full coilovers
  1. -2.5 degree front camber (proably will do ASAP, hopefully that's the cure)
  2. Toe out front (daily driver with a lot of miles, I would rather not)
  3. Reduce rear grip by adjusting tyre pressure (Don't actaually want to reduce grip anywhere, I want traction going out of corners still)
Any other suggestions and personal experience with this platform is appreciated!
Well if GT86 is the same platform and kinda similar, the best way forward if tyre pressures don't fully cut it, is added neg camber in front imho from experience with the forefather. Toe out works for turn-in but not much if at all on corner exit.
Drive around is a way but irl driving, safe slow in, fun fast out may indeed trigger understeer bit too often.
Another way is a thicker rear arb but that actually compromises traction especially with a Torsen lsd (more likely to lift inside rear wheel).
What sort of speeds? Surely if you are in 3rd or lower, just press the throttle? Higher gears, yes there may not be enough torque to load up the rear tyres.
I found the GR car understeers more than the old GT, but I see this as a sort of sign of maturity, because when pushing on you feel understeer at the limit initially, but now you have more torque to deal with it than in the older car.
Understeer is good to gauge grip levels, as long as it isn't terminal understeer....
Having done a track and drive limits day on stock geometry the understeer is very much there, but a strong lift or power application will bring the rear into play.
Think of all those journo videos showing it dancing around on track on standard geo not one of them complaining about understeer.
I have used my car at millbrook. I can confirm there is lots of understeer over the limit and giving it full throttle will not drive the the back out. You can completely overcome the understeer by trail braking and carve any arc you like. had a go a lot of different techniques and trail braking is the answer. Best not to try and work this out on the road. Left foot braking will also tighten your line nicely.
Yea, I do found the car not very sensitive to trail braking compared to my other cars.
Others will respond to small lifts and progressive trail braking, to get the same effect on the 86. I will need to be very rough as if I want to really upset the balance before it respond, throttle lift barely does anything at the moment too. Let's hope even more camber fixes it!
Got to admit stardust that’s not my experience of the trail braking. Seems like we are getting some confusion here between trail braking and lift off oversteer. It does not respond as dramatically as some front wheel drive stuff but you definitely can drive around any understeer as witnessed by all the magazine boys antics. Don’t doubt the stock set up is not the ideal track day warrior setting but then no car is as factory. All good fun experimenting. There is not enough power to drive the back out at the Apex although I guess we could try and give it a little sharper turn in.
I will be interested in hearing how you get on with the camber on road and track. Keep us updated Stardust on your findings 😀
Trail braking I can make it work but lift off oversteer (general throttle adjustablity) is my main issue. If I go massively sideways everywhere with throttle oversteer, yea, I can overcome it but outside that it doesn't do much. Car feels abslutely fine on a autosolo due to that but shows the issue on faster longer corners.
I am actually comparing the GR86 with my other car S660, which is a mid engine toy with a lot more grip and 50% of the weight. Just shocked to find more understeer which is harder to overcome overall than a MR car in the current state.
If it underststeers in a steady state mid corner and you're happy with camber, tire pressure and suspension, then you could adjust roll bars (softer front, or harder rear)
Yes, but as I mentioned higher up not ideal on torsen rear as it will tend to lift the inner wheel faster and thus lose all traction at that point.
Reactions: hsb
See what you mean now Stardust. I guess I personally would notvhave any need for oversteer on long fast corners as it would likely be followed by a massive impact given my skill level. Guess that’s more drifting set up so agree would likely need a major change in set up. Stiffening the rear I guess is the way to go. Plenty of people drifting GT 86 who would have the answers. Have you tried Fensport?
100% , I will need to book in an alignment place for more front camber first.
There is so much potential in the chassis from the GR86, but it feels like Toyota is holding it back from us day 1. Completely opposite to the FL5, where it feels great from day 1 but kinda feels like it's at the limit of FWD and the chassis.
All cars are naturally set-up for understeer, and rwd will generally be set up with more understeer then hot fwd cars that can afford to be on the edge without risking sending the general public overconfident driver into the hedges the first time they try esp off and try the throttle... So your observation is correct even in a broader sense.
On track you can indeed find the front-rear grip balance while trail braking, doing this on the edge of the grip circle will send out the rear easily when going on throttle.
In real life roads where train braking into corners is usually a no can do 95% of the time and slow in fast out is the proper way, one can either forcefully provoque the car (scandi, left foot brake and/or even handbrake), or add add more front camber so you can be balancing the front and rear grip limit on very light throttle so more of the latter sends the rear out. But be aware of the consequences on higher speed evasive handling, so need to find a balance that works for all handling traits and not just focus on that one handling scenario...
I guess I haven't been driving normal road cars for so long, my S660 on Modulo suspension will spin you like a top if you lift mid corner wrong, the EP3 Type R daily I sold is setup similar to a Civic Cup spec .
Neither need any provocative to balance front and rear grip when fully loaded middle of the corner. Amount of throttle will control how much oversteer/understeer you get.
I love that the throttle can fully control the car that way, but I guess if the car will instantly spit you off the road backwards if you lift off too hard or worse, slamming the brakes on, might be a problem for some.
Might play with bars as suggested if camber wasn't enough, but also would look into coilover if I have to start doing bars already
