GR Yaris Which short shifter? Forge, Airtec, Foresight (non-CAE, etc.)
  • Total voters
    32
I have foresight, feels more like 50% less throw, rather than advertised 35% I believe. Very nice for spirited driving, but feels as excessive force is needed while cruising. Also trying to be very gentle while oil is cold. I'd suggest this or similar design if you dont have all the mounts stiffened.
Yes Marco, forces are higher (approx. doubled). The good side of this - if you're interested to "feel" your car - it improves feedback, especially for people with gross motor skills. About 40000km tells me it's a stealth solution which works :-).
Bye for now Fred
I've been running the Foresight quickshift for almost two years and feel it transforms the car as it's much more precise with a rifle bolt feel to it. I was fortunate in being able to try it on a friends car before buying. In comparison the OEM gearshift feels vague and it's easy to moneyshift if pressing on 😬 πŸ’₯πŸ’°πŸ’°It was easy to fit as a DIY job. Happy days!
Thank you for the feedback :)
So what is your setup (which exact parts from which brands apart from the Foresight short shifter), if you don't mind me asking?
20mm alu machined spacers under the shift mechanism, forgot what they are called, from Australia.
35mm extension of the shift shaft/knob that I made myself. A taller knob, perhaps from the GR86, does the same job.
I increase the shifter height cause it felt low down after installing a steering wheel spacer (which other cars mentioned before had too). So not necessary perhaps on an otherwise stock car.
TGR performance 25mm? I couldn't fit those to be suitable for LHD, they move the gear shifter to the right, so made custom alu ones roughly same size.
Those indeed. I just twisted them so they shift to the left instead for LHD, worked fine. Easy enough to make oneself if one can be arsed 😁
Have Foresight, no issues.
Do again, probably Forge as it looks nicely done and is adjustble. But no actual experience.
Ref feel, I already thought the foresight was pretty short at 35% less, almost notchy. Higher knob/longer shaft fixed that. Airtec much to short imho.
Unfortunately need to correct myself. My foresight failed completely. I had loctited the mounting screws, but it was the pin that became loose. I do run solid bushings that probably made it worse and why it happened now, but still necessary to be cautious and good to check it now and then...
Guess I'll have to check mine, also running solid bushings. Iirc, I have noticed some corrosion on the bolts as well.
Now running the Forge Short shift. Adjustable pin feels much more robust, still put some loctite on just in case...
Oh, don't bother with more than 40% reduction in shift length, I tried like 55%, very short but you loose all shift feel and only feel the slop in the system and that's with all my solid bushes.... At 40% it feels 'normal' to me, so very similar to the Foresight that got that part just right (no need for adjustable).
Happy GRY motoring all :)
PS: I have also tried the CAE as is and it is very nice in feel, direct, clear and plenty short. I think the close gate works best with racing seats, so you don't move about when shifting....
Oh, don't need that, see my above edited PS: comment.
But have you tested both in conjunction? Sorry, can't read that out (translation). I think things get worse in connection with the CAE. But I don't know.
No sorry, just the CAE as is (edited post to make clearer). Don't think that needs shortening, if anything, I would like some more sideways spacing on that one.
Thanks Buddy.
I have installed the CAE since the beginning. I also did the whole bushing thing. I find it crisp as bright and love switching gears in the car. I think I'll leave it like that and not try out these additional short shift parts, I think it'll just be bad.
The only thing that would really be cool. The clicking switching noise like in Brian's Eclipse in Fast and the Furious. But then I wouldn't be able to drive anymore because of all the shifting :))). You know the cool sound?
Thanks Buddy.
I like the idea of the CAE shifter that its (high) price has gone down a bit over the years.
Could you please share the exact parts you chose for the bushing, please?
(I'm referring to parts like the LAMSPEED RACING 6061 BILLET SHIFTER CABLE BUSHES, not bushes for the torque mount, etc links with the engine.)
Thank you!
I have the Hardrace Bushings ☝🏻.
If you have installed that including the CAE, I can't understand how you can order the car as an automatic. Sure is faster, like 200 million other cars. But that's exactly what makes this "mechanical" car special. Wonderful.
I believe I require these as my gear shifting doesn't feel as nice, tight and precise as it did from new!! :confused:
I don't currently have an aftermarket short shifter either but I'd love to try someone's CAE on a meet... :unsure: :love:
:cool:
:cool:
You might want to check the state of your torque mounts
A few report from fellow member said that it made quite a difference with the shifting.
Yeah I have the whiteline inserts but they only helped make it feel better for about 500 miles, I must drive it too hard lol... πŸ˜…
Going to have to go full torque mount, other mounts/bushings... :unsure: 😁
  • Haha
Reactions: Ono
Foresight short shifter fitted today, and a good few test miles followed, what a game changer! The shifter is adjustable, I've had it set at 50% of the max reduction in throw which has given a noticeable reduction in throw, and made changes feel much more positive and direct. For me, it's significantly improved the gear change, and added to the driving experience. Happy days!
