GR Yaris Dump valve
You'll need aftermarket management to do that really mate, otherwise it will bog (like evos do with an atmospheric BOV on).
With the standard ECU it will bog and maybe put a light on. The air that you're dumping has already been accounted for by the MAF, so too much fuel will be added. It's worse at low speeds.
Would a catch can also cause issues due to "restriction" in flow?
-it shouldn't.
As long it's a quality catch can (and not venting out) it should not trigger any issues.
Mine hasn't - at least yet... knock on wood! πŸ˜…
-it shouldn't.
May I ask which one you have and for how long?
I've got an Airtec one, sitting in a box for few month now. Don't know why I'm so hesitant on installing it... :cautious:
same as you: Airtec!.. it's about 1000 Km since installed (so far so good).
Generally speaking seems like a good quality item... very little details that could be better were:
that aluminium bracket is too chuncky/heavy - made me spent about an hour drilling holes on it... :ROFLMAO:
the o-ring for the dip-stick got damaged out of the box - so I replaced with a quality one (green rubber /viton)
For me, has given "piece-of-mind" knowing I'm doing the best I can to avoid oil into the combustion chambers... specially considering the GRY combination of direct-injection/boost/high compression ratio and hard to find 98 besin sometimes.
I have got a forge motor sport one, it comes wit a new solenoid tooπŸš—πŸ’¨
