GR Yaris DTUK Stage 2 Box fitted. First thoughts.
Engine basically runs lean up to 3900rpm, so adding much boost below that without proper AFR control is a bit risky. On the V2/race there is MAF signal manipulation, perhaps telling engine more air is coming in thus hopefully tricking it in upping the fuelling, but not sure how control logic works vs lambda control.
Anyway, upping boost until a fault code comes on and then stepping down isn't what I would call a failsafe tuning regime.
Anyone feel free to correct me, here to learn...
Totally agree with this.
A very well respected tuner in Nissan and Toyota circles said he wouldn't touch a tuning box with a barge pole. It's just not the right or safest way to tune an engine. You are just adding boost by fooling the ecu.
I remember my old MR2 Turbo, the previous owner had wound the boost right up without me really knowing ( I was only 20 at the time), the gearbox imploded about 3 months into my ownership, not fun.
Having said all this there will be plenty willing to risk it for a few bhp. To each their own and all that.
I would use a box if I could properly log all relevant parameters (EGT, timing pull, (real) boost (spikes?), fuelling etc), and be able to finetune it myself for my car so it never even runs close to trouble...
So what would you say is the safest way to safely add more Hp to the GR?
German cars are usually tuned down due to engine sharing and respond to tuning boxes better. I've found Japanese performance cars are in a higher state of tune so don't take to remaps and boxes. Imho
Bolt ons at this stage. I suspect if you delete the opf, get a good cat back on, an intake, you would probably see some decent gains. Again, I wouldn't do the intake because of concern over filtration but to each their own.
There is the syvecs ecu but I think you lose a load of standard features and it is thousands of pounds.
This engine is new and may have weak points we are not aware of yet, it is also likely to be highly strung as it is.
If you watch the YouTube video of a tuningbox yaris vs standard there is hardly anything in it. Makes you wonder if its worth the potential borkage and warranty issues down the line.
Safely adding power? It's always a risk, but for me who intends to keep this car 'forever' and thus emissions compliant, it's about adding hardware/bolt-ons that lower (thermal) load and increase efficiency and improve response, and perhaps adding some boost in the low AFR region (>4000rpm) to pick up some of those hardware gains without going overboard, with logging verfication (EGT, IAT, Timing (pull), etc). To do the latter looking for a box that allows for making own adjustments. Or some more transparency on what this (on-topic) box actually does and how it is verified...
Not looking for numbers, more about making the engine even more enjoyable in response and in revving it out...
Emissions compliancy is less of an issue for most at this stage, than legality/insurance cover, because for most owners an MOT is not coming up for a couple of years at least. I have a GPF delete pipe, but it's in a box in the garage until the day I decide to take the GRY off the road. You really need to check the small print in your insurance, because some will state removing any emissions components can invalidate the car altogether for road use. I have a tuning box too but I still haven't installed it, although AFAIK insurers seem more flexible with them (can't stress enough how important it is to declare ALL mods).
There are a few people around with issues engine wise and each of them had or have a tuning box so I would go in with your eyes open. One guy on the other forum has confirmed head gasket failure. I know the fanboys will say it proves nothing but personally I won't risk it until there is further evidence one way or the other.
And there are many more who have probably run a box for a year on the Yaris with no issues.
There are so many variables that it will always be hard to say what caused someone’s failure was it user, mechanical or modification.
If you tune any vehicle it will be under more stress so components are under more strain, it's a lottery really. Pay your money and make your choice 😁
I was involved in a lot of the mapping back in lockdown a year ago. We did have some issues with triggering EML's and also the reduced engine power message that affected early chassis numbers. Though I should add this happened even with cars not fitted with the tuning box. It is still an occasional issue with early cars. I typically get a reduced engine power message every couple of months.
I've had the box on since my car was two months old. I have now done 20K miles. I think it's fine in all honesty. It is only a slight upgrade in power which is barely tickling the engine with a 10% power increase.
While that is certainly true, it is also true that you are adding risk by installing a tuning box. If you value your warranty a tuning box makes little sense in my opinion. If you are not that fussed about the warranty and willing to take your chances for a little more power, which a lot of people obviously are, then you can.
If you value a warranty you wouldn't change anything. Changing an exhaust and intake would be enough to consider grounds for not being covered if you had an engine issue.
Intake yes probably. I think a cat back is OK but it will be down to Toyota at the end of the day. A tuning box is certainly worse than a cat back.
You’re contradicting yourself by saying “value your warranty don’t get a tuning box” then advising people to buy bolt on parts (which technically a tuning box still is) implying they wont impact a warranty and as you stated an intake probably will impact.
I didn't think that was implied and even so, that's the reality. With a few exceptions, software/box will increase the load on an engine and manufacturers will automatically invalidate any drivetrain warranty if an investigation shows any manipulation. And be sure, if an ECU is sent for analysis a box will leave traces.
Bolt-on hardware on the other hand isn't as straight cut as it may very well improve the situation. For instance, an uprated cooler of any sort rarely invalidates warranty if an issue wasn't directly caused by it. Similar for a catback exhaust.
Some bolt ons are ECE approved, meaning that where EC legislation applies, it is even illegal to deny warranty as manufacturers cannot stop spare parts from 3rd party suppliers, again excluding the part itself obviously or when it was clearly caused by that part.
We're getting potentially going into an endless discussion about legalities, point is, some mods are more likely to invalidate the whole drivetrain warranty then others, and piggyback boxes, remaps and aftermarket ECU's are on top of that list, that's the main take-away.
PS: for clarity, I'm not implying in any way that it's ok to claim warranty if you know issues are caused by any modification. On the other hand, I also don't agree on easy blanket refusals of all drivetrain warranty for unrelated things or know issues (e.g. leaking water pumps), therefore I do think it's ok to not give too much reason by e.g. removing a box, or ideally, if such a relation exists, to have this discussion with your technician.
Not really as I think it is quite clear how a tuning box is always going to be seen as worse than say a cat back exhaust when trying to make a warranty claim. Yes it could be that Toyota blame the exhaust if you have engine trouble, but they will definitely blame a tuning box if you have engine trouble. I am not advising anyone to buy bolt on parts, my only point was they are probably overall less risky than a tuning box.
HKS have an ECU type product coming out in the next few months..
I am keen to see the price and what can be done with their kit.
