GR Yaris Suspension Secrets Seat Lowering Bracket
coded2112
Dedicated member
Has anyone fitted this bracket to there car? I believe it lowers by 35mm? But removes the sliders?
Makes it a bit impractical hence why perhaps not a great interest, saw one for sale on the dark side!!
Sorry forgot to put link on for details
The lower seating position is achieved by removing the factory-fit seat sliders and replacing them with bespoke lowering plates that bolt directly to the chassis floor.
I think no one wants to remove sliders except for track use.....and for track no one would drive stock seats....so its a useless product imho
Yes i tried to convince myself that only i drive the car and it was a cheap option for a lower seat but have decided that it is not for me...
I’ve ordered one last week
I always have the seat as far back as it will go, don’t carry passengers and if I do put the kids in it’s the passenger side seat that slides forward on tilt for rear access anyway so the loss of a slide function doesn’t bother me
Interested to hear your thoughts once fitted, please!
Mine came the other day I’ll get it fitted when the wind dies down!
I think the issue is no matter how low or far back the seat goes my elbow hits the door card. The recess in the door card is in the wrong place and isn’t deep enough I have to sit with my shoulder pushed forward
I think this is possibly the worst driving position car I’ve owned for years
Strange pricing on these; £180 for one and £60 for a second one (£240 for two) plus £19.99 shipping for both options
Anyone with a LHD version want to go halves?;)
The driver side is the same on both LHD and RHD apparently
Yea £20 postage was a piss take
I order the pair of seat lowering plates and so far I’ve just fitted the drivers side.
A big improvement for me as I’m 6’6” tall. Already had the www.spacershop.com steering wheel hub fitted.
Might leave the passenger seat as it is so that access to the rear still possible. However it’s usually only just me in the car.
Long term I am tempted by a pair of Recaro CS seats trimmed to match the originals so as to try and achieve a bit of an OEM look.
If the passenger side plate fits the drivers side for a LHD car then I might well pop that on eBay and that hauls back a bit of cash for me and gets a cheaper seating option for an owner outside of the UK.
I think the drivers seat base is the same for LHD and RHD. It’s not side dependant it’s seat dependant and the passenger seat has different hole spacing
Good to hear you found it worked - I’ve got mine ready to fit but the weather has been no good for working on the car!
Did you fit yours in position 1 in the instructions (think that’s the furthest back)
I asked them why in position 1 the seat can’t be pumped fully down and they said it can as long as you move the airbag plugs as they get squashed otherwise. Position 2 and 3 have little spacers though
I’ve got som 2,3 and 5mm shims I might fit under the front too to try and tilt it back a bit maybe
Position 1 which is furthest back. It was a little tricky reaching to tighten up but otherwise all ok.
Seat is a little further back and height drop is on 35mm but it’s a significant improvement if you are as tall as the likes of us. I’m much happier behind the wheel now.
im about 6'3 would you say option 1 is further back than the stock seats go?
Yes, not a massive amount but you’ll find the seating position much improved being lower and a tad bit further back.
Well fitted mine this afternoon, followed the instructions and it was strait forward until you try and get the rear seat mounting bolts in.
What a pita very little room to get the 50mm torx tool and ratchet under the seat to tighten them up but did it in the end 👍
Im 6ft 2 without heels on 😱 the seat is now perfect for me i no longer feel my head is in the rafters when driving 😃 the car has just me 99% of the time and no one has ever been in the back seats so is a perfect solution for me without spending a small fortune on replacing seats.
Great stuff - hoping to fit mine tomorrow if the weather os decent.
Did you fit yours in position 1? We’re you able to full pump the seat down to It’s lowest setting or was the airbag plugs in the way?
As far back as she goes ie position 1 👍 seat goes down to just touching the plugs, which is fine for me as I don’t want it any lower 👍
