GR Yaris Good vid explaining cylinder offset
His videos are very good :)
Iirc correctly the 1.0 ecoboost was one of the first ones, actually bought a Focus and had it for a year out of sheer curiosity for the then new engine. US visitor thought it was a 2.5 V6 is quite telling... Since always wanted a performance 3-pot and look what we got...
it beggers the question why arent all engines built with a bit of off-set!!!
The balance thing explains it pretty well, I think.
For a four cylinder it introduces a huge amount of extra complexity, weight, and cost so it’s a big ask for such a marginal gain.
For a three cylinder there are already a lot more inherent balance issues that need to be managed via balances shafts, non-uniform flywheels etc. so this only changes the parameters, therefore the penalty for going with an offset crank is relatively small, hence why we’re seeing more of them.
Has anyone heard of piston shattering like glass ? I saw on one of GTR-GTR-GTR's videos where he shows a photo of such a damaged piston. It actually is unrecognizable. He says there are stories circulating on Social Media about GRY engines blowing after modifying with piggy-back ECU or similar and being thrashed. Apart from money shifts, I haven't come across any yet.
There have been reports of pistons shattering when used in competition or under similarly harsh conditions.
This has occurred with stock ECUs, rewritten, and motec.
The cause is not known, but there may be a clue in the areas that have been strengthened by the GR Corolla.
In any case, it has nothing to do with us who use it on a daily basis.
Any engine will break if run too lean.
Gr seems to vary its afr between 11-12.5:1.
Have been asking the best afr for direct injection engine in mid to high rpm range but it appears to be secret.
Heat and fatigue probably part of it. Just because it takes +500hp for one pull doesn't mean it will last forever....
the case that he was showing in his video was taken from this video:
Great video. Would be a good own thread to have all potential issues that cause engine explosion.
- moneyshift -> overrev - > lost valves and holes in crank case.
- exploding Pistons(?)
- valve float -> see point 2.
- dissassemlbing rocker arms -> see point 2.
Please continue the durability discussion here:
i think toyota still do it on their 4 cylinder engines
Oh, I wasn’t saying it’s never done, just that it’s not as common. I imagine a smallish offset can be countered by a normal balancer shaft, which many 4-cyl engines already have.
Thanks for the video Yuri1312. Looking at it and the two others that follow on the same subject, if I understood well (Youtube translation) it appears that the piston shattered due to 3 things :
- Pre-Ignition at high load
- High pressure built up in that cylinder at that moment
- Restriction of the OEM catalyser not helping to evacuate heat and partly the peak pressure when the exhaust valve opened.
All that due to ECU mod / Motec.
However, and as White Rabbit said, there may be a clue in the areas that have been strengthened in the GR Corolla engine...
Now I'm convinced about the benefit of the HJS downpipe catalyser !
that was my understanding as well... they're not discarding the possibility that the pistons might have had some manufacturing defect, but for sure in the right conditions they will break (and as we've seen with the valve springs, toyota did change those and the material of the pistons in the GR Corolla engine, so, also leads me to believe that those are known weak spots by toyota, who don't want to issue any massive recall given they only blow up under specific non oem conditions).
regarding the oem cat, it's also known that it is very restrictive, which will, of course, reduce gas flow. drive the car hard, running more boost (higher egts), and i'd say it's a recipe for disaster...
