GR86 GR86 Duckbill spoiler install
I think thats about half the UK price 🤷‍♂️
Is the spoiler supposed to be completely flush?
Mine has a small lip as in the photos, noticeable on the close up.
Not sure if I’m just overanalysing after the door ding.
I think if you follow the template thats what you end up with, i cant confirm but ive seen that a couple of times and not liked the look of it. Reason i went with the no drill method
Ahhh fair enough, this is what they said too. Thanks that’s relieving.
Think it gets slightly exaggerated because of the contrast bumper but it’s noticeable of you look really close .
Im guessing your spacing will be even on all around and near the ends, in comparison here is mine;
if you line up along the rear, notice the bigger gap on the front . You lose a little bit of the rear clean line as you get towards the edges showing the panel was definitely made to sit more central.
I suppose the rounded top edge of the boot means that if you mount the spoiler any more rearwards you'll have an awkward undercut between the two.
I still can't decide if I want one, looks good with or without to me.
Exact same situation and price.
just waiting for the temperature to rise a bit before installing as I don’t have a garage.
Was quoted this for fitting without any drilling : "your duckbill spoiler will be £588.05 fully fitted", from Macclesfield Toyota - think I will be sticking it down myself ! Guessing they were including the drill at that but even so !
May I please ask a question to Pearl white owner who installed the ducktail - is your spoiler colour matching your body colour? I ordered one from Toyota Japan which coded K1X but it was not exactly matching my body colour…
Mine is a little bit more whitey than my body colour and wondering if yours have the same issue?
That's annoying, and part of the reason I went black on mine.
My pearl white Yaris is definitely more white than my pearl white GR86 (n)
20c on Saturday, so I’ll chuck the duck on.
Anyone had any issues with the 3M only method?
Just don’t fancy red lining on the autobahn only to see something floating away in my rear mirror.
Not that I've done autobahn speeds in mine, but 1000+ miles with no issues so far 🤞
Its fine...
My supra's is glued on with 3M tape just the same and the acceleration is much more brutal, and it's a faster car and that's staying on and I've been to an airfield and tested it at well over 120 on a private strip (that I know the owner of).
Just remember, that 3M takes about 72 hours to cure fully.... I think top of my head its 50% strength after 24 hours, then achieves the full strength at 72 hours.
