Dav1d
- Dec 18, 2021
- 533
- 794
I think I’m going to - garage is pretty damp anyway!Keep it outside![]()
I will have a think - if only there was a way to mix them with the circuit pack upgrades from factory. Maybe some other driver convenience aids in the mix tooNot tempted to get parking sensors?
if it's not a secret, how much did that service/oil-change cost? (so I can prepare myself...)Had mine in for an oil change at 6700-ish KM. They also said they would do a software update or something. A “factory campaine”. Don't know what it was and forgot to ask. I’ll chuck them an email.
I dropped Buttercup at the local dealer where they're going to pull the transmission and hopefully solve the problem where it keeps popping out of 2nd gear.
In the meantime, I'm driving my Avantime for a week or so.
Oooohh, going to need some details on those lovely bolts!Changed some heavy stuff for lighter stuff, installed a custom Öhlins Suspension and the rear diff. cooling kit from HEL.
View attachment 13360View attachment 13361View attachment 13362View attachment 13363
Let us know how Hel's cooler does. I'll run Cusco cover and HRNSHN vent combo after winter.Changed some heavy stuff for lighter stuff, installed a custom Öhlins Suspension and the rear diff. cooling kit from HEL.
True, after fitting the steering spacer, I immediately felt the the shifter was too far down as spacer tilts whole upper body backwards...Gear shifter riser goes hand in hand with spacer, they should sell those as combo![]()
They‘re Grade 5 Titanium bolts where the damper meets the hub.Oooohh, going to need some details on those lovely bolts!
Yeah it's the Coolwalk upgrade. It's been lurking in the version that came out in early Jan but they've been slowly rolling the actual Coolwalk part of it. So the two versions exist in the same update but they'll slowly add more and more users to be able to see the new feature.My Android auto interface is different too. I think Google pushed something out.
