GR Yaris Oil grade
j22b
Interesting one had my gr serviced today and noticed they had put 0w16 oil fearing they had put the wrong oil I went back in and talked them about it and they adviced they checked with technical and that was adviced as correct.
Checking directly with technical thenwas able to confirm both the 0w20 and 0w16 oil is listed as correct for it and can take both safely with many here in Ireland now running it which is very interesting as hadn't heard of any in the UK running it
wasn't aware anyone does 0w-16 but that aside most important part was it ILSAC GF -6A type oil
This wasn't from a service tech I also assumed it was a f**k up so went to the technical department in Toyota and cross checked and confirmed both are correct.
It seems 0w-20 was indeed the factory fill but now 0w-16 is listed also (specific spec of 0w-16 can't remember the spec) on Toyota internal catalogues
still bit unclear...have they installed regular Toyota oil or GRY specific ILSAC GF -6A
The technical department at the dealership? The ones who used 0w-16?
It's to stop pre-ignition, which will shorten engine life. Got to keep on top of what they are doing - as they are not always the brightest in the service departments. Plus it is more expensive and possibly more difficult to source. A Yaris Hybrid GR is a completely different kettle of fish, as the name refers to a trim level. The hybrid unit is always aiming for low revs and ideally engine shutoff for the battery.
the only oil viscosity the manual for the GRY mentions is 0W-20, if they told me 0W-16 was put in they'd be getting told to change it, for the first service I took my own oil and will be for every service for my own peace of mind
think it's safe to say based on your conversation with service agent you've got the wrong oil in your car and they neither know of or have the correct oil in stock
No not aware of any technical departments in a dealership, it was Toyota head office technical department here, only for them showing me the internal reference and the cross references I'd have wanted it changed.
They still offered to get it changed to 0w-20 if I wanted but showed me the documents to support that's there now listed for it as well so hopefully saves someone nearly having a heart attack at the dealers like I did đŸ˜‚
I would still go by what Toyota Japan prescribed, ie what's on your engine oil cap, not any other Toyota franchise or otherwise.
I would perhaps consider deviating from what's on the engine oil cap only if there are newer/future iterations of the API SP standard, eg sth like an API SR, that are retrospectively compatible with API SP (and with all other factors like viscosity equal, ie still complying to the engine oil cap requirement).
Most of us have been through this oil saga and when I had mine done I made them show me the oil, they really were not happy about that. The dealer had barrels of 0-16w for std cars and gallon jacks of 0-20w sn+ for GR (but not sp. ) The document they printed off had all the models listed and for the GR in UK 0-20w sn+ was acceptable. 0-16 was not. I don’t do many miles or track my car so accepted the sn+ but if my car did any work I would definitely change it myself to SP. It only takes 30min.
I would ask for the oil compatibility list if I were you as I know 0-16w was not on it when I saw it.
So, what's the forum consensus on the issue?
Just got back from the service, noticed 0w16 in the bill, ended up in this thread. Should I call them and ask what's up? Should I replace oil to GF6A myself?
I would ask them to redo the oil change as they have used wrong oil that can cause damage to the engine.
If they decline in writing then you have at least valid case if anything happens with engine.
My car is a March 2023, and the JDM paperwork only specifies 0W-20 SP GF-6A. GF-6B is the same where LSPI is concerned, but has lower HTHS. So lower high temperature high shear. I asked the local Toyota network and they said the only GR Yaris that takes the 0W-16 is the RS.
An update on my case. I wrote an email to the dealer politely asking if 0w16 is not a mistake and that I am concerned about it. They naturally ignored that email, until I forwarded it to regional toyota distributor. Dealer called me back same evening and invited to change the oil to my prefered grade.
So, yeah, according to the dealer 0w16 is accepted, but anyway they changed my oil to 0w20 on their own expense. For the next service I will explicitly ask for the 0w20.
