GR Yaris “Engine Maintenance Required - Visit Your Dealer”
Have you had fault codes read from the OBD and what did it say? Standard procedure when visiting a workshop... Could also be possible it needs a reset.
Not sure on this platform, but disconnecting the battery and let it sit for say 15min could help.
Just general suggestions, I don't actually know exactly how these things are implemented on this car.
Thanks for the suggestions. I checked for fault codes via Torque Pro + OBDlink dongle when it first happened, there was nothing. Might Techstream show something different?
I also disconnected battery for 30 mins before taking it to the garage last week, this is the first time I've seen it since battery disconnect.
I don't believe my luck with this. Proper gutted right now!
Could you not have it put back to standard and see if that cures it?
By the way, an LS430 is super cool in my book 😀
I'm sure it will, it's definitely to do with this pressure pipe though as it was fine for a week so it should go away once I sort that properly. Plus it's 80 miles to go back to installer. I'll think twice before going so far for this kind of work again, that's for sure!
I know what you mean, I am not travelling far to get anything done on the GR, it's just too much hassle and time to sort it out, especially if it goes wrong.
The tube from cat to engine has split! Is there so much pressure going through this tube? Or maybe there was too much play and it touched the cat? But it doesn't look melted...
Luckily he has a much thicker tube which should go in place so I should still be at Drive Limits on Monday 😃🤞
