You mean up the a-pillar? ‘Smart repairs’ are perfect for that kind of stuff imo
Yeah - sort of above where the drivers window is (roof was a bit misleading). That’s good to know. @Mike - bog standard pure white so hopefully not too bad but yes will need a few layers I imagine. Meant to post pictures this morning but forgot (and it’s far too dark).
Found some stone chips along the roof beam right through all the layers of paint (like something has been kicked up and bounced along it as the chips get smaller further back ).
Anybody got experience with something like ChipEx? Is it quite easy to do yourself or am I better taking to somebody that will do a proper job and perhaps combine with some detailing/washing at the same time?
Use chipex on lots of cars and it works very well
Today I almost had another accident. My right of way on a roundabout and what speed I was going was neither here nor there :( A guy pulls out and decides to panic and stop. I didn't hit him, Cool as Hamilton like I just waited until he moved and sped on.
Yeah I get more people pull out infront of me in the Yaris than I do the Focus as I think they barely look and think to themselves "Oh a small white car I can beat that" Then you meet them on the roundabout like whaaat!? :oops: o_O :rolleyes:
Sadly, the state of roundabout discipline here means I always expect people to pull out on me, regardless of what I am driving.
Had a few (very!) close shaves as people consider the outside lane of roundabout to have priority, so if you're barrelling round on the inside they will happily pull out into the outside lane, regardless of your proximity, speed, or indication status 🤬
I could tell this guy was thinking about it but he left it until the last minute.
aww man my biggest peeve is lane discipline as I have a roundabout outside my house and people drive down the middle of the two lanes to go straight ahead! AARGGH! :mad: ...constantly have to watch out from being side-swiped!! :( 🫣
Don't know about the rules over there, but over here both parties have simlar duty to yield for that outer lane, of course its an issue if both go for it at the same time... A good driver I would say will see what's unfolding and avoid any incident, and next time, be sure to be in that outer lane already :devilish:
That thinking just leads to what people end up doing here; always driving in the outside lane, even if they are driving 360° round the roundabout and passing 3 or 4 exits*, because then they have “priority”.
*inevitably without using indicators, of course
We usually have signs on the entry that dictates which lane one must take so they would be in the wrong usually in such case....
Swedish drivers are pretty meek, some almost asleep at the wheel, one learns how to drive around* them...
*with proper distance and indication, speed is hard to measure in a roundabout ;)
half way between safety check.
Took 2.25 hours...
All ok and included a recall of the emergency button
Fitted my Aulitzky exhaust and was forced to install the GPF again because it was way too loud and raspy when the valve was open... it was basically strait piped after the cat . With the OPF back in its place its still loud but sounds much better. On the other hand its crazy how quiet the exhaust is with the valve closed having only a single silencer in the back.
For anybody thinking about this exhaust: I used a contactless Can Hi/Lo adapter so I don't have to modify the original cables of the vehicle. Didn't want to mess with the OEM wiring harness as Aulitzky wants you to use a power thief connector which cuts the cable behind the dashboard. So far it works great! Exhaust can be controlled through the different modes sport/track. The adapter is called: Teltonika Ecan01
Took it in search of A and B roads that don't have any potholes.
Down to the Borders via the A68 and back up the A7.
:D
  • Love
Reactions: Gyp
