GR86 Hill start assist
OldManMarkoos
Devoted member
Has anyone experienced the hill start assist working?
Mine seems to be disabled or doesn't seem to do anything.
You should see a little green (?) car on a hill on your left dash if it's on. Having tried this on a hill, can confirm it only holds for a few seconds and the car will start rolling back.
Yeah... No green car hill symbol for me.
I'll try the enabling routine tomorrow.
Just wanted to make sure it's not another feature they forgot to install 😉
Did you have to enable it?
Nope! This is symbol @grzoostuff is referring too:
Think it can be disabled, was looking into it as seems pointless on an auto
Page 254 of the .PDF manual (on the Toyota site) goes into detail about the operating conditions and also how to disable it. If I'm reading it, right it only holds for 2 seconds.
My Mazda holds for about 2 seconds too, never looked into whether it could be switched off or not, you get used to it. Although being old school I tend to instinctively grab the hand brake on steeper hills.
Same here. I think it would be a more useful feature with an electronic handbrake, but as we have a proper manual handbrake, muscle memory means I tend to just use that anyway.
It only seems to activate on an actual hill. Small inclines I can't get it to activate. Not a big deal but annoying...
When it does activate I think the green symbol flashes instead of being steady?
I see it active on smaller inclines too, it just doesn't last too long.
  • Wow
Reactions: WpR
Never had this feature before, its a nice touch I like it, its really not invasive and works well.
This feature works really well on my FK8, its the first thing I turn on when I start the engine, but on the 86 I find its absolutely rubbish!
or maybe I haven't got the hang of it yet, I did see the symbol flashing today?
Agree on it being rubbish.
Was on an actual hill for the first time in 1000km and couldn't get it to activate (press brake hard)....
I wish it was easier to turn it off/on, don't want to go trough the 30-something button-press-process.
Thread necro, rather than start a whole new discussion. I came across a post recently where someone said that disabling hill assist made pulling away and shifting in lower gears feel easier. I was curious, so I decided to look up the procedure to disable it (I never use it anyway, it doesn't hold the car long enough and I feel it's a little redundant with a manual handbrake).
Anyway...I might be going mad, but I feel like there might be some truth to the theory. I always find pulling away first thing in the morning a little jerky. I put it down to the car being a bit tricky at the best of times, but today, after disabling the hill assist, it did feel like I was able to pull away a little smoother, with less of a need to balance the throttle quite so precisely.
I figured this must be a placebo...right? Surely the hill assist is only having an effect when it's triggered? I assume these systems work simply by holding pressure in the hydraulic system until you press the gas or release the clutch...but I've no idea if that means they can have an impact even before they are triggered...I'd like to find technical info on how they are plumbed into the clutch and brake system.
Anyway. Here's a couple of posts with others who's experienced the same...although for balance, lots of others tried it and noticed no difference. Also a video on how to disable the system if anyone wants to try.
Procedure to disable:
1. Engine on.
2. Hold Traction Off button for 30 seconds (until it reverts from Track mode back to standard mode).
3. Within two seconds, press Traction Off again.
4. Hill assist symbol will go off, then come back on.
5. Switch off the car, then back on...Hill Assist should be disabled and dash symbol stays extinguished.
Will give this ago, I don't like the green icon being on all the time, I get when the car is stationary but don't get the logic why it remains on when you have set off?
Currently in Italy with an Opel corsa hire car. The hill start seems perfectly calibrated to hold the car just to the point where it brake-boosts you up the tail-pipes of the adjacent cars while parallel parking.
Great job Opel 👏
@WpR Hill assist (green) light flashes and only works when the clutch is pressed down and the car is in 1st gear on up-facing hill; it keeps the brakes on (if light is flashing on) and car held by brakes for a small time when you take foot off the brake pedal. It stops the car rolling back as you get your foot off the brake and onto throttle and time to let the clutch out to move away. Works in reverse gear too if the hill is big enough and it is pointing downwards for reversing up the hill .
