GR Yaris Driving Mode on the road
Which mode do you usually drive in on the road?
  • Almost always NORMAL
    Votes: 26 18.8%
  • Almost always SPORT
    Votes: 24 17.4%
  • Almost always TRACK
    Votes: 33 23.9%
  • Usually NORMAL
    Votes: 17 12.3%
  • Usually SPORT
    Votes: 6 4.3%
  • Usually TRACK
    Votes: 10 7.2%
  • Favour NORMAL
    Votes: 1 0.7%
  • Favour SPORT
    Votes: 3 2.2%
  • Favour TRACK
    Votes: 9 6.5%
  • Depends - don't favour any
    Votes: 9 6.5%
  • Total voters
    138
When I start the car, it all happens automatically. Installed some wiring harnesses.
Engine On
-Start Stop off
-Lane Assist off
-IMT On
-Track Mode On
The best mod is the Lane Assist off.... i hate it sooo much.:))
One more thing I need is: "Expert Mode" ON.
I only use the car for blasts and I'm glad I don't have to push the crap every time.
Is this the little ATtiny85 solution MagnusT described on The Other Place?
I've gotten better in this. when started the car,
left hand presses line assist while right put's the iMT and sport mode one. after that right hand moves to TC off.
When line assist is off left hand moves to back button to go back from warnings. So technically you can have all off in 5sec.
Must be a left hand drive car.:rolleyes:
based on it, but @Greenthumb is running a plug and play solution I built for him :) Very shortly he'll also be running something to automatically disable traction control as well :D
If you're interested in something like that, DM me :)
By the time I have got started got rid of the stop start and lane assist and pressed the IMT , got my brain in gear I usually drive in N but flick to Sport or Track at interesting bits depending on where I am . In normal driving 60/40 is fine and when I discovered that your starter in stop start mode does half a million starts versus 50k in the cars lifetime I stopped stopping! Having replaced a few starter pinions I’m my life and flywheel rings with teeth missing . The future owners of my classic in the making may thank me !
But the starter is designed for this, it’s not some traditional starter than someone added some software to the ECU. It’s like saying if I drove my car 10,000 miles that millions of rpms rather if I drove 50 miles thats 50,000rpms. The components have been tested and proven to operate at this frequency. There is a 10 year warranty on the cars. Use them, use all the features.
Isn't stop/start disabled when in sport and race?
I am well aware of that but consider also the reversal loads on big/ little ends rods bores etc . In my day we used to talk piston speeds but as F 1 cars can do18000 rpm one wonders . The stop start is an EU invention ! Should be banned with Brexit!
Isn’t like 90% of all engine wear from start up, does start/stop not cause more wear and manufacturers don’t care as long as it gets through warranty period?
I believe that’s a cold start , not a warm start. Though I admit theoretically going from 0 rpm to 1,000rpm must be a shock.
Manufacturers don’t know how every car will be driven, and how every component will last, if they designed every component to last the manufacture warranty period they would have 1,000s of failures, as such they build in huge safety factors (for reliability)
I’m again sure it adds wear/load but all considered, and factored in. Have you seen big ends , rods , bore wear evidence on any stop start car? I do understand your point, but we can’t speculate, without evidence, and my point is, I suspect Toyota have more evidence pointing to fact it’s probably ok, than we do, that’s it’s not ok.
We are a few people on the internet, thinking theoretically with past experiences, but Toyota have likely tested it, before sign off.
Stop / Start should in theory not affect bore wear , as it not sat for too long. Loading on the big ends etc, I’m unsure of the torque applied at 0rpm to get to idle.
I actually drive the car, trying not to avoid stop start, so I reckon I’m pretty up there with stop starts now 😅😂
The whole idea of stop-start is to make cars more economical. Several motoring journalists tests show a real world 10% increase in economy (unless you are a conspiracy theorist). With the current price of petrol it does make sense to use the technology.
However, I think it's a PITA so always turn it off on my cars.
As a vintage car owner 82 years old , the car not me but I’m catching up ! These GRs will be
Classics ( are already!) so poor b.gg.rs like me will be trying to find starter pinions etc ( or 3D printing them ) . If you need to worry about cost of fuel don’t buy a car , any economist will tell you that . This little gem needs to be treasured!
just reached 10k km !
Drove +100km recce roads last weekend and sport mode was perfect there to get the car rotated. Not the fastest way but definitely fun
