GR Yaris New Turbo ?
Wancho-GR
Absorbed member
Gibraltar
I have a big mess in my head if I should install a big turbo or not.
Which turbos have you guys fitted?
I have bought
Kelford cams Ez and Springs to install and not sure if I should buy the Syvecs and a turbo to achieve 390-400 bhp with 98 oct pump fuel.
What are experiences with these mods?
Thanks 🙏🏼
I have bought
Thanks 🙏🏼
Hi.
If you aiming for 400hp you not gonna need a bigger turbo. Original turbo is good for 400hp with the right supporting mods. You'll run out of fuel at +400 anyway.
I choose the TTE400 (now named TTE500, but the same stuff) solely because it was the only one available at the time.
With real 400hp and some nice torque it's almost to fast to enjoy on the roads. (Depends where you live of course). On track it keeps up with the GT4s on the straights which is hilarious.
I would swap cams, springs and try to find someone thats maps the stock ECU. Would make the most bhp versus cost.
Hi.
any issue from this type of high flow turbo ? some vendor claim they try many of them and they are fail but it was back in 2020 or so
i am consider this type of upgrade too. with more flow i can reduce the boost and lower dwon IAT temp to redcue knock
I don’t have much confidence in the hybrid turbos to be honest.
Many out there seem to fail once driven hard on track.
If you daily it for fast roads ocasional blast its fine but not for the use I want to give it.
I guess the Garrett G25 turbo kit is the way forward.
Buy cheap buy twice….. I have experience on that over the years unfortunately 😞
No problems whatsoever with my turbo. Drove 10000km 2022 and 50% of that is on track under heavy load.
As I did both turbo and cams, springs and stuff I cant tell what diffrence just changing the turbo did. But my car sure is breathing a lot better on top than any other Yaris I tried. The low down torque is about the same as we cap the max torque anyway but then it revs all the way to 7600 with no need to take boost out of it.
Makes for a nice curve and a good driveability.
I only choose hybrid because nobody had a complete kit ready.
I would love to see what a G25 could do on high boost but you need some more stuff to utilise all that Power and everybody might not want to go "all-in".
If I would start all over I wouldn't bother with turbo at all. Plenty enough with maxxed out stock turbo and some supporting mods.
Another benefit with the hybrids is that no one can tell you changed it compared to a full frame turbo kit that would render to much interest from cops and at the early car inspection we have to do in Sweden. Both are equal illegal but one is easier to sneak past curious eyes. 😇🤣
G25 turbo kit might be push the envelope of stock drive train
I already have enough trouble with stock turbo
But u are right stock turbo will run dry after 6000rpm this is reason I am considering Hybird ~
Looks like Whifbitz have done ~550bhp at 2.3 bar on a G25-660, with cams/head work/rods&pistons.
I'm really curious to see how the rest of the car copes with all that power.... gearbox will give up, transfercase and diffs maybe?
Such power levels are usually either 'drag racer' or show(-off) car, not something that last for 24h races so to speak.... In the latter case even 400hp would be impressive and in need of lots of mods...
My tte turbo was really good untill it snapped.
Did it use the OE ball bearing core or do they change it to some journal bearing system?
Shit!
How old was the turbo and how many km?
What preassure did you run it at?
Shit!
About 4 months old, 2500 miles and 1.8 bar.
Happened on a track day with fast long bends with 255 semi slicks on so not sure if was oil related. I know of another tte that started passing oil though to. Gone Garrett now and will have dry sump fitted before it sees a track again maybe a bit ott but better safe than sorry.
Mine see a little less boost but have 255/265 semis on and I drive pretty hard on track. Would love a full frame kit but the wallet hasn't recovered from last years parts and tuning yet. 😇
TTE hasn't the best rep in Sweden sadly but was the only choice 1.5 years ago when I ordered mine.
Now there is better options available. Or if you dont chase a lot of power stay with the stock turbo and be happy. Properly tuned its pretty fast anyway.
Looks like the turbine has delaminated from the shaft. The turbine is friction welded to the shaft. You can usually use a magnet to see if it has failed directly at the friction weld.
My back ground is diesel engines. Failure at the friction weld is unusual.
Too much exhaust heat can cause this type of failure and over speeding the turbocharger> too much boost.
If its not obvious, turbocharger speed is directly related to boost pressure.
