GR Yaris My Evo 6 build to GR Yaris build...
Looks good.
Would be interested to hear if the noise levels have increased much.
Loving it. Bit of a photoshoot after I coated it all.
I think I’m going to go for a set of those Pumaspeeds. In bronze.
Did you happen to weigh them before fitment? I know they quote β€œ10 kg” but we all know what vendor scales can be like…
Also, did you use any spacers?
Hi.. No sorry I forgot to Weigh them but they were definitely heavier than the 8kg stock rims.
No spacers used at all. Not needed.. As they are 18x9.5 ET42
πŸ‘πŸΌ
Wow - Those photos are incredible. Its like somethings been photoshopped o_O
Yeah that is genuinely wild. It’s definitely not a perspective thing, right? The first time I saw a Yaris I was surprised how big it was but didn’t realise it was like that vs an Evo
New forged carbon gearknob fitted... From p3. Auto on here.
Perfect fitment and quality. πŸ‘Œ
Up next was the toms rear vents....panel beater of 27 years,not a problem.:D
WRC plate fitted
Eventuri gloss carbon filter fitted....
DTUK V2 tuning box with updated maps...altered bracket to fit with strut brace.
DTUK pedal box and obd2 adaptor for torque pro app
Hi Mate
Iβ€˜m trying to install the Pedal box on my Gr Yaris and struggling to remove the existing plug that’s already in the accelerator am I doing something wrong as should be easy right?
Hi Mate
Hi mate... You have to push in a small tab in the side and pull at the same time ... This releases the plug. πŸ‘πŸΌ
Thanks Phil
Mine was a right little bugger to get off, but did it in the endπŸ‘ Have you any suggestions which setting is best as we have similar Mod’s
Thanks Phil
There is "city" "sport" and "sport+"
Mines on "sport" -2 and is very lively.
If i set it to sport+ then its basically undrivable as its so sensitive.
Busy boxing day.... Mrs out at the sales...., 😁🀚.... So cracked on fitting some upgrades.
Airtec intercooler kit with Pro hoses.
Airtec oil cooler kit
PIAA horns
Bumper mesh behind the oem grille
HEL brake lines in GR red front and rear. Brake Fluid flush.
Millers EE Oil change and filter.
Carsifi AA adaptor.
Well,with 80 miles on the clock I decided to fit a few bits. :)
LED number plate bulbs
Gloss black Yaris badge
TRD side skirt extensions
Airtec front strut brace
Pumaspeed 9.5 wheels....zero issues with 255 tyres and lower -25mm.
@Philevo6 where did you get the black Yaris badge from? I remember seeing posts about them, but have no idea when πŸ˜‚
