GR Yaris “Engine Maintenance Required - Visit Your Dealer”
TheManWithTheStick
Anglesey
Last Wednesday I had a certain sports cat/downpipe installed. I'm booked back in next Monday so not going to name any product or garage names just yet in case this is nothing major, I'd just like reassurance that my car is safe to drive the ~80 miles back there.
I drove home from the install without issue and the car felt like it had good bit more grunt. That evening I went to see a mate about 15 miles away but on the way home I hear a loud bong and this scary "Engine Maintenance Required" message appeared on my dash!! I can press the back button but a few seconds later it pops right back up - it seems quite important. There was no CEL or any other warning lights. I stopped the car and let it sit for a few seconds, upon restarting there was no message and I continued home without issue.
I checked the manual and found reference to this message under the GPF section on p.218. I've read that GPF can be removed without issue so I don't understand this, plus the garage said there is no sensor in the GPF so they're a bit confused - is that right?!
On Friday I went out again and after driving for 10 mins or so I was accelerating from about 3k RPM in 3rd and the dreaded "Engine Maintenance Required" reappears. The car seemed to be running just fine so I continued my short journey and phoned the garage who installed it who booked me back in for Monday. The message once again disappeared when I next started the car.
Last night I was accelerating in 5th from lowish revs when the message appeared again! I thought this might be caused by engine load at low revs and maybe I need to give the GPF a good blast so on the way home and kept the revs high and was accelerating in 3rd when the message appeared once again.
Toyota serviced my car about 2.5k miles ago so I don't think it's a service warning. I can't find any reference to this message in relation to the GRY. Has anyone had this (with or without mods) or know anything more?
I can’t help much, but it is right that there are no sensors in or after the GPF, so removing it shouldn’t cause a direct fault.
So you had a downpipe installed AND the GPF removed at the same time or just the downpipe?
Sorry misunderstood, if you’ve removed the cat and not the GPF, then my understanding is you can get a CEL or similar then, because the secondary O2 sensor (after the cat, before the GPF) will potentially pick up the missing cat.
It's not de-cat but a sports cat, and like Phil says a few have been installed with no issues. Just my bloody luck really 😫
Does anyone have a clue what could be wrong? Could a loose bolt/gasket or something simple cause this??
Exhaust leakage can cause faulty readings, as can do a damaged o2 sensor, damaged cable etc
Joining the dots as to where you had this installed, I would say it could well be a fitting issue
I have personally forgotten to plug back in a few sensors in my days, on my own cars, only to scratch my head and then facepalm said head o_O:ROFLMAO::rolleyes:
As I understand it, for EU6 models, the pressure tube in the primary cat will interpret an increase of pressure as a blocked GPF.
I think the question is, is it safe to drive to the installer? Impossible to answer to 100%. If there is no CEL in theory it should be ok. But if the engine ECU gets complete wrong sensor info, it might think all is well, but it actually isn't. Sure is that the chances of things going south go up a lot if driving hard. But if you want to be sure, put it on a trailer...
Given there was a mechanical sound before the CEL it might be that something is leaking or not right in the exhaust? I'd take the car to the place where the pipe was fitted and let them check the install.
It was a "bong" from the dashboard and not a mechanical sound, thank god! Sorry for any confusion
Can you get under the car to take a photo?
NOTE: the pressure tube is not connected in this photo.
