Ive took all sound deadening off (cover & hood & intake)) and like it.Hi everyone, anyone tried to remove the engine cover? Does it make the engine sound louder?
Try and test - easy to do. Though assuming it will deaden mostly high pich noises such as injectors etcHi everyone, anyone tried to remove the engine cover? Does it make the engine sound louder?
Only the original designer has the final answer.does the engine cover have any function? airflow, cooling, noise reduction, better look, heatshield?
Agreed. In fact one of the most untidy looking engines I've seen.not the best looking of engines with no cover on![]()
I might have added a few wires here and thereAgreed. In fact one of the most untidy looking engines I've seen.
that is one ugly looking engine.... one of the ugliest I have ever seen.Only the original designer has the final answer.
But me speculating, it has proper function for:
- Looks
- Noise reduction
- (minor) pedestrian impact (not much cushioning, but more benign shape - however without it there is a bit more space so that might also be beneficial depending on point of impact)
No proper function:
- heatshield: no obvious hot parts protected or heat shielding in the part itself
- airflow: somewhere in the presspack there is some explenation that there is a little airflow guide on top of the cover that improves airflow towards the turbo helping cooling it. And to that I say, yes that probably the case compared to an engine cover without that feature. However no engine cover will *most probably* allow more air to flow over the engine and further improve engine bay and turbo cooling, and anecdotal evidence from a few people tracking stage 3 cars suggests the same.
- Cooling: airflow and radiant cooling for the cylinder head should be improved without cover
Spot the mods, I'll pop it back on when going in for service for the looks
damn this is porn... does the head function like an intake plenum like on the BMW S85 V10 as well?
Not as far as I know. The plenums are on top of the engine (with the Audi badges on them) with the heads being below and much lower down.damn this is porn... does the head function like an intake plenum like on the BMW S85 V10 as well?
All the 'race cars' have it off so cannot see it messing up much of sensors. I'm quite sure its only for decorative purposes.Not sure the slightly increased noise without the cover is desirable, perhaps a bit raw injector sounds or maybe even messes with the knock sensors? And indeed looks like sh*te. Perhaps just remove it when doing something like a trackday or a really hot summers day... In the boot then.
