For my understanding, what does "aggresive toe all around" translate to for this 4WD car, please?... I got it aligned before the trackday and I’m at -2.5º in the front with more aggressive toe all around...
do the RPX put grief on the discs or are they reasonable kind ?EBC RPX and stainess steel brake lines - best brakes Ive ever driven. Stops like nothing else
No clue - they state moderate disc wear but need to get a micrometer and follow up how they tolerate..do the RPX put grief on the discs or are they reasonable kind ?
Far out! That is getting mighty quick for a stock 1.6L car. Wonder what the GT3 driver was thinkingHad another session at Alastaro with GR Yaris. Now with Boes seat console that is a good improvement for faster driving, no moving around cabin anymore and position during cornering was planted. So happy with that.
Managed to shave off almost 2s of previous time, now 1:33.4. Still think there's 1-2s to improve (stock brake pads & street tyres) as drive was far from neat and there was time left in two fast corners still. So good time starting with 1:31 with street tires and maybe 1:27-1:28 with semis?
Fun car with this setup, however too understeery if pushed fast track driving so maybe it is a compromise with this setup. Works 90% still and great on road.
Has initially problems getting heat to rear tires even though in last stint managed to get some heat there aswell.
Managed to overtake one GT3 and couple of race cars so in that sense it was good paced session.
Likely idling or poor driver. No change against fast GT3. Still, it happenedFar out! That is getting mighty quick for a stock 1.6L car. Wonder what the GT3 driver was thinking![]()
Set on! glad you like themEBC RPX and stainess steel brake lines - best brakes Ive ever driven. Stops like nothing else
Hey man, sounds like a fun day!Had last(?) fun session yesterday at local race track. Cool day, so had a goal to improve PB on the track as on last visit it was so hot engine was totally soaked.
It was tricky to get tires up to temperatures and actually they did not heat up that well, but managed to improve on last session as track dried out.
PS4S is stange tyre. felt like it lost the best grip after one lap even though it didn't get so much into temperatures. Could be placebo as well, but definitely more understeer was there.. All in all, good for maybe one lap but after that it is not longer gripping so proper track tires are recommended if more track fun is in plans.
Friend was using 225 semis - that could be a still usable approach for stock suspension.
Had a short code brown moment in one of the faster corners when car's rear end snapped in mid corner - could be that I was lifting or breaking too much in corner entry (can't recall exactly) but all in all it was sudden and kind of scary experience. Luckily managed to avoid spinning. Should try to replicate the situation again so that would better understand when does it go.
Fun car overall, especially now when there is more confidence to take it to the limit. Being gentle enough with the front end to get the car rotating and then getting the best corner exit seems to be the way for good laps. I think that current car setup (alignment) is good for track too. It's more up to the driver to put the car into its place.
If faster times are required then semis and coilovers would be the path.
I thought positive toe = toe out. So, reading the relevant bit of your post above as "front toe in & rear toe out" leaves me scratcing my head.Front is -3deg and toe is -1.6mm F and +1mm R - which worked great, understeer gone!
It's the other way round.I thought positive toe = toe out. So, reading the relevant bit of your post above as "front toe in & rear toe out" leaves me sceatcing my head.
I probably got something wrong. Could you please clarify, for my understanding?
Thanks
