GR Yaris whiteline lower torque arm bush kit
Ordered the power flex lower torque mount. Is it worth getting the power flex upper engine & gearbox mounts as well?
I'm on the fence. While I've found plenty of references about torque mounts and inserts making a positive difference, I haven't found anything similar for the other two GRY inserts you mention.
A couple of hints in the form of theoritical opinions, like the one above, suggest that they shouldn't make such a great difference. Powerflex, of course, recommends installing all three.
The inserts don't cost a lot but I see risks relating to their installation:
  • Fiddly to get access to where they need to be installed;
  • Main dealers don't seem particularly keen to do the job;
  • Professionals who will fit these will either charge a lot (considering the low value of the inserts) or fail to put everything back together properly (so many bolts to be torqued) or both.
Torque mounts on the other hand, whether the whole part or just an insert, should be circa 30 minutes to do and a relatively cheap job, especially when done as part of a service where the car is up on the ramp with the undertray off anyway.
Did you get the engine and gearbox insert as well in the end?
Installed mine a few days ago.
I chose the whiteline because it keeps the orignal vulcanised mount, and because it fills the holes fully so reducing risk for undue rubbing and wear.
However, the big lobes that are not loaded under power (as the core is pushed the other way) were a bit too hard for my taste. They are just there to reduce the rocking of the engine but being so hard would in my mind transfer unnecessary amounts of NVH. So drilled some holes in them so they flex a bit when squeezing them hard with my fingers, making such holes in the mould are a bit of a hassle I suppose...
For me, I notice a bit sharper response on initial throttle, and indeed slightly more positve shift. Both appreciated when on it. I also notice more vibrations on start-up, and a bit harsher running of the engine up to 3k rpm ish, with some more pronounced vibrations through the shell. Mostly noticeable when engine is cold (its freezing here) and it almost completely disappeard with heat in the engine and I suppose mount also.
Also, once before I did manage the car to wheel-hop, I suppose this will be less pronounced with the insert.
None of these changes are night and day, but rather subtle. I know this is how I perceive it, because I can be quite forgetfull and yesterday I already forgot I did this, yet noticed the cold engine sounded bit different/harsher lol.
So all in all a little shift in compromise, from comfort towards sportiness. Non-essential imho but I do like it. But I'm happy it didn't go further, that would throw out the existing balance of properties of the car.
Update one year on. I had actually forgotten I have this in, meaning the added NVH has completely settled down.
Which also makes me suspect the less void filling variants will probably have lost some of their initial effectiveness in reducing movement with miles, that was my experience on a different platform previously at least.
I think it's a combination of parts/materials bedding in and us getting used to the increased NVH.
Yes and as to getting used to it, sure a little but it was very noticeable the first winter (harder rubber at cold temps) at cold engine with the interior vibrating a bit much, that disturbing NVH hasn't shown itself at all this winter which is how I could 'forget' I did the mod.
what were the torque specs to big and small bolts for torque mount?
Got some additional vibration so could check that bolts are mounted as specced once fiddle there.
Small 60Nm and big 120-140Nm?
