GR Yaris “Battery Charging”
Sturesmyg
pianofingerpower
Not that I necessarily want the start stop thing to work, but: when I stop at a light I get a message with the start-stop ‘A’ with a line across and the text Battery Charging (only in Norwegian).
I read it as the car can’t stop and run stuff on battery power due to low voltage aka needs charge. Should I connect a charger over night and see, or should the battery be sufficiently charged over the 191 km I’ve drive by now?
Thanks!
How long are you leaving it between journeys? How long are your journeys?
I drive mine at least once a week and after 5-10min of driving start stop kicks in. Not that it’s a good system it’s very crude so you end up going straight to sport mode and killing it.
Mines brought that message up 2 or 3 times in the 15 months / 11k miles I’ve had it. I think more so over winter
Ive had it since Friday, so its been driven every day. Guess aprox 40 km per day ish.
I used to get that when I had teething issues with my immobiliser that were draining the battery, but once resolved I can’t remember seeing it again. Sometimes it’s unavailable due to climate control but that’s about it. Any chance of parasitic drain from dashcams running in parking mode etc?
The only thing I have plugged in is this speed-trap "radar" thing that uses GPS. But I dont think it uses any power when the car is not turned on. Then again it is actually plugged in the 12 volt cigarethole thing. Maybe thats it?
Normally there is no current available there when vehicle is switched off, but do check if you can.
I would just drive some more and see if the situation is resolved, my start stop hasn't worked much the first half year and now it does it all the time, don't know why...
Fully topped up battery from a trickle charger and stop start works on mine.
A 300 mile trip, parked up overnight and the stop/start won't engage next morning. Too small OE battery for real world.
My stop start is over keen. I don't use the car for a week and then when I do it cuts the engine at the lights half a mile from my house. It does however give up and re-start if I'm there for more than 20 seconds. Witchcraft if you ask me!
Given it probably hasn't been driven much before you got it, it's likely charging the battery. If it's still doing that in a couple of weeks then I'd wonder.
