GR Yaris LW light weight lithium battery and charging options
Cranking analysis shows that the battery is on the lower side .. 🤔
Did this after (car) sitting in -17’C for a one hour.
-17°C isn't the same as +17°C. Difficult to find reference values for such circumstances but I've seen cars start without issue winter time dropping below 10V, anyway it's still in the OK range.
Yes true
Guess if I managed to keep this baby away from the GR ?
Battery was dead easy to install and fitted 100% in stock place - no additional hw needed.
Initial tests - cranking power is up by 3V. Starts much better with new battery.
Did small test run and must say I can feel the weight difference. Stock battery is like pig to this one!
Installed wall mounted charger which upped up battery in 3min so it seems cars own charger manages charing quite well.
Checked from the remote battery status monitor and car was charging constantly between 14.2-14.4V so near perfect.
Let's test now in real life
- how fast does it drain out if car kept stationary
- how it tolerates living in Finland. I'll start taking my jump starter with me if there's any longer times that car needs to stay parked outside in cold.
On VAG you can choose a li-ion battery in the 'OBD dealer system' or 'techstream' equivalent, wonder if that is the case here too?
Appears the car or the battery does the trick as alternator gave nice 14.2-14.4V all the time during test drive
Unfortuntately the BT battery monitor does not seem to give full status of the lithium battery due to BMT - shows constantly charging which includes no status or % charged status..
In terms of lithium battery and cold weather usage - one recommended life hack is that if you try to start the car in cold weather, it is useful to 'heat up' the battery first by consuming some amps from the battery before trying the first start. This reduces the internal resistance of the battery and thus it can provide higher starting amps.
Battery Heat up can be such as putting the cars lights and other consumables on for 30-60s before 1st startup.
Need to test this in real life how it goes.
Kind of bugged that Remote battery monitor does not seem to work with batteries with BMS but thought it indicates some status that available Volts are still visible.
Given where it goes in the battery's range (10.6-14.6V) probably gives an idea if there's any juice left..
was there any spesific tricks to put car in sleep mode (I know you can disable the remote access, but would it help much in battery consumption)?
Could anyone that has access to Toyota Techstream check if there is various battery profiles or charging options available for GR?
Drove today a roadtrip to ice rink and back, travelling time 9.00am and back 13:30.
To the lake charging was ok but after we started driving the track charging Volts seem to be dropped and not returning to normal.
Just wondering if alternator has some kind of "sleeping" mode and car would deliverable consume battery charge from time to time. On long term it might be beneficial but then again, if battery level happens to be on the low side and you happen to leave the car parked for longer period of time you might be in problems..
Here's my charging volts from today's trip. Charger gave battery status 30% which is way too low given car was driven quite many hrs - should be closer to 90%..
Asked our Toyota dealership - according to them there is no spesific setting for different batteries in GR nor for charging modes. Normal charging rate at 2krpm is 13.2-14.8V. Charging volts can vary depending on engine load, battery temperature etc.
This does not explain the lower wolts I got..
theres clearly two modes in the charging (can also be battery / BMS related) - constant charging and then mode where charging is dropped for some reason and battery runs clearly without alternator charge. Thought this to be vehicle/ecu driven but who knows..
Checked the car's consumption when sitting in garage for 24hrs. no measurable loss, maybe 0.01-0.02V consumed in 24hrs.
It doesn't seem to loose much Volts.
For that charging issue - I think it is BMS (Battery Management System) related topic so Battery manages its charging depending on conditions.
I'll top the battery up if know theres many days of car being parked and not driven but given the consumption when being parked don't consider that being any issue.
Battery acting again quite interestingly when visited a doctor.
Ambient -4'C.
Car seemed not to charge much while drove to city center (it did fo few initial km's but then was off for a while).
Car set few hrs parked and then drove back home. then altertor Voltage was 14.3V.
Real life testing data from LiFePo4 20Ah battery
Car spent outside 3days, temps between -10'C to 0'C.
From Voltage history all seems good but my charing app gave red alert from cranking Volts (reported 9.7V).
Car stared normally though. Did not "preheat" the battery as it is recommended for LiFePo4 if battery is in cold (consume amps for 30-60s with lights etc)
For daily use I would choose the 40Ah variant
Still very light but double capacity than the 20Ah variant. Theres about 60 mAh running without killswitch I read? Correct?
maybe this one fits better for intelligent alternators? Dont know if yaris has one, but saw that there are 2....both 20 and 40 Ah available
But these batteries are very good examples for light ones that fit p&p. Thx for that
My understanding is that recuperation batteries were for the use where car collects power from braking etc. As in GRY it is used 'normally'. CS Batteries recommended the basic one for GR so that was the thinking..
For me, I don't think I am gonna change now but when eventually the battery needs changing, that 40Ah looks like a good upgrade_while_changing_anyway for a daily used/sometimes sitting 2 weeks car without worry about top-up charging too much (I have no garage and even if I had not fond of charging with small kids around).
