GR Yaris MPG and other data nerdary
So I thought id best start off by actually displaying some data
Hopefully now we can see the reduction in the MPG during winter, this is collaborated by the fact I can no longer join the motorway without the "temperature too low" message. It's not actually too must different to summer as the coolant is thermostatically controlled. Question is the oil?
Petrol prices remain circa £1.619 around these parts for Shell / Esso so a tad upset, but I will continue to fill with above 98 Ron, I was caught out as I surpassed £60 with ease, for context I never used super unleaded in car before this and we have an LPG car, so there is quite a difference to get over :ROFLMAO:.
On the Dacia front its costing about 2.5 times more to use the Yaris than the Dacia (35mpg on LPG at £0.65/l) purely down to the cost of the fuel.
So my mileage is reducing as the other car (mercifully) gets used.
In other car related news the Fiesta has returned to my ownership and is on its way to be a more track focused car. I may post in the other car thread
Not a MPG update (one on the way) but I can confirm the GR makes a good jumper vehicle for car with a flat battery (another car had been sat for some weeks), a few looks of “why is his boot open” but all good.
Makes a difference to the weak battery thread 😂😅 the GR is my strong battery car
There are jumping points in the engine bay.
I didn’t even think to check haha. It was actually easier to jump from rear, as the striken car was blocking the GR in on the drive.
Behold an update, just one fill up so nothing to really report except petrol prices
In other news the Yaris is going to do its and mine first Auto Solo. I have a track car but the tyres aren't eligible and I don't really need an excuse to enjoy the Yaris so its going.
Hoping that with the handbrake, 4wd and low cc I might even no be last :ROFLMAO: even if I am ill still have fun.
Ill post about it in the motorsport/events section, hopefully see a few more people there
Where’s the autosolo?
I did 2 last year. The first was a refresher as I hadn’t done one in years and he Yaris being bigger I kept hitting cones but when I did do a good run I was seconds clear of the 4WD class. But just not consistent. 2nd event I won (although only 2 of us that time).
Yaris in theory still smaller than a modern Clio by a few mm, though it’s 100mm wider than my Mk6 fiesta. But saying that it does feel wider when you drive it. I guess it’s because of the arches, I am less confident precisely where to the mm the wheels are. Plus the pricey wheels makes me scared sometimes
Coming from an Abarth it’s about 33cm longer and 18cm wider. Feels like I’m driving a tank!
Enjoy it and let us know how you get on. I ran in track mode and expert mode, on tight turns it caught me out just how much it oversteered but easily manageable.
First time on Tesco Momentum Super , let’s see how it feels
I rotate between, BP, Shell and Tesco. It makes no difference to MPG, which is about 31.5 whatever brand I use. It obviously runs a bit better on BP, Ultimate - possibly because it costs an eye watering 1.65 a litre up here.
BP is 97 octane ? The lowest octane super. You mean Esso?
Only Esso , Shell and Tesco are 98+
But if you can’t tell this is useful info
So an extremely long drive to Rutland today pick a inlet manifold (other car) and while travelling along the M6 I thought id take some measurements of MPG then compare them against the square law to see what I found. surprisingly I found an extremely strong correlation. I found myself arriving with a solid 41.5 MPG on the tank readout (which had some previous miles on prior to this trip)
This might not be 100% accurate but certainly has enforced my belief in never (although I can't say that due the data) exceeding the speed limit on a motorway. I drove the majority of the drive at 60-65 mph also to see the effect of this slight reduction in cruising speed on the ETA, there was exactly none, however im aware its likely at 70mph I would have gained 1-3 mins over my 2 hour journey.
Save the fuel for the fun sections of road
