I'm replacing mine with Endless MX72 pads when they are finished, great enthusiasts road and a few trackdays brake padbut they do seem to dust a lot!
As per above, have you looked at the ones that Rotheli racing found?I I need new front discs after 4 pad changes and 7 track days but only 5500 miles.
beat that.
Is there a warning light for pad and/or disc wearAs per above, have you looked at the ones that Rotheli racing found?
I asked Phil about this and they were unsure as to whether they are going to make the discs or not, which is a real shame as they look good.Is there a warning light for pad and/or disc wear
Unfortunately still not sure…I asked Phil about this and there were unsure as to whether they are going to make the discs or not, which is a real shame as they look good.
I know their 'stuff' range of pads have been questionable over the years but their RP1s got a great review by @DeanoC after some hammering on track.I know this is going to cause a difference of opinions, but if ebc discs are as poor as their pads I'd stay well clear.
PS - the car offers no warning for worn pads, nor I assume discs. If you're doing hard middle pedal work, I would defo suggest a regular visual to make sure you're not in for a surprise. If you're around any trackdays alongside me, welcome to come grab some temp paints for the discs so you can get a sense of what temps you're running
Assuming you meant pads rather than discs, yes they do, on the inside pad. The problem with that is that, on my car at least, the outside pads wore out faster, and wore more on the top of the pad than the bottom (where the squealer tab is)I thought that the standard disks had the little sticky-out metal squeal indicator on the inside front (but not rear) so they make a racket when the pad is getting low.
I could have imagined this.
BTW, if the stock pads wear fast rather than the disks, I'm sticking with stock pads, irrespective of how much dust they create!
Was going to say exactly the same. You could not pay me enough to put green/bluestuff on my car, but I respect DeanoC’s opinion on the RP1.I know their 'stuff' range of pads have been questionable over the years but their RP1s got a great review by @DeanoC after some hammering on track.
how would they perform in winter?I'm replacing mine with Endless MX72 pads when they are finished, great enthusiasts road and a few trackdays brake pad
Had them on previous car with no issues wintertime.how would they perform in winter?
That said I'm actually thinking of staying OEM, not tracking so they don't wear quickly and when they are done it's probably a good idea to clean the caliper at that time anyway. Only annoyance is OE dust profusely but it also seems easy to clean off so no biggieI'm replacing mine with Endless MX72 pads when they are finished, great enthusiasts road and a few trackdays brake pad
