Got my winter setup today. Pictures on the car will be posted come winter👍
Can you use the standard wheel nuts on these? I don’t have the ultra, only leggera. Wondering if I need to buy separate nuts for them
No the standard nuts are the wrong type of nut. You will need 60deg taper nuts if the bolt hole is big enough you should get ones with shoulder bolt to ensure enough turns.
Like GRunt and Spaceman say, they usually come with own nuts and are different from toy-nuts..
Typical "accorn" type nuts will do. ..just for example:
Am pretty sure the guys with OZ run that style to get enough thread engagement
WedsSport 18 x 8.5 ET 43 wrapped in Yokohama Advan A052 235/40/18.
Rims weigh 7.5 kg each, each tyre weighs 10.3 kg. Total = 17.8kg. Lighter than stock. Plenty of room for neg camber and for lowering.
