GR Yaris HELP: PID for RPM flying on canbus
amarce
Absorbed member
Hi guys!
I’m working on my own active exhaust system and I cannot find the correct PID for the RPM; I’m sniffing the green and white can and I’ve got coolant temp, tps and speed, but I cannot correctly identify (and find the formula) the PID for the RPM… I thought that was 0x1EA on bits 2 and 3, but it seems to not be RPM really… I’ll keep checking on the bus, but if someone has identified it you could help me a lot… It’s the last missing bit for my active exhaust 😭🤣
I’ve also got the current AWD status so I can switch modes with the central knob (I neede to use both canbuses on the feather M4), but I am lacking this bit!
I know that @MagnusT has dissected the canbus and maybe has the answer, but I would be very happy if someone can help here.
Thanks a lot guys!
Hi guys!
Thanks a lot guys!
Here is the thing working by TPS (I want to mimic the exhaust valves on how abarth works; by speed, TPS and RPM).
Hi, thanks for the reply; yeah I’m using savvycan and this methods but there is a lot of flying data around the bus; a lot of values are changing with the engine stopped.
Right now I have on the left side, green and white bus the following:
0x361 Bit 2 -> TPS
0x0AA —> wheel speeds for 4 wheels independently
0x1EA Bit 0 -> coolant temp
On the right side of the car, on the blue and white bus the following:
0x51E Bit0 -> AWD mode (0x80 for normal, 0x82 for sport and 0x8A for track)
I have not been able to capture button presses, only mode changes so to change the exhaust mode, the AWD mode would be changed (at the moment 3 times in my setup).
Tomorrow in the morning I’ll do a short capture with some known RPM values and will check for a little or big endian and let’s see what appears there
Hi, found it.
RPM is 0x115 BIT 0 and 1. The correct calculation seems to be: ((Bit0 * 256) + Bit1) * 0.79
It shows pretty accurate data and my acoustic shift indicator seems to be working too:
Edit: It's weird that I cannot hear the acoustic indicator from my computer but I can from my mobile o_O
Well, the “thing” is almost finished and ready to be mounted in the exhaust:
Exhaust modes are selected by the awd button
The case has been also customized
how are you reading the CAN bus of the car?
I'm trying with a Peak CAN and Savvycan but i only read 2 ids no matter what
I’m using savvycan. You cannot read on the obd port since it has a can gateway. You should undo the panels on the feet and take readings on each canbus (are the twisted wires). I’m using contactless canbus adaptors to read the data
Amarce are you able to take a close up photo of the canbus wires you are reading from? I am struggling to decipher the wiring diagrams to find the appropriate twisted pairs. Cheers
Hi,
On the left and right doors you have the blue and the green canbus. One has the data for the engine, the other for the comfort. There is another canbus that I have not investigated a lot but maybe is for lighting or symilar.
The weird thing is that you don’t have the same data going around left and right doors .
Hi,
what do you mean by ön the doors"?????. Do you mean the main harnesses that run along the sill panel and the connection blocks for them at the bottom of the A pillar onboth sides?
I
The case has been also customized View attachment 5453
It would be lovely if you could share what contactless CAN adapters you are using. And also which connectors/wires go to what network. Highly appreciated. Very cool what you've done, to open/close the valve with the dial!
