GR Yaris LW light weight lithium battery and charging options
Michael Knight
Finland
Have been looking around good LW batteries for GR.
Have noticed that lithium batteries are often offered with spesific chargers, i.e. C-Tecs would not be applicable.
Got me thinking that how does the battery then work with cars own alternator - would it have same issue or would the cars charging logic need to be updated if lithium battery is used?
this seems to be a good option even though it does not have that nice features like Liteblox it is quite a bit cheaper. (500€, less than 2kg)
Spesific specs
Technische Daten:
7,5Ah TrackTOOL Batterie
Typische Nennspannung: 13,2V
Ladeschlussspannung: 14,6V
Bordnetzspannung: 13,2V
Zellenzahl: 12
Startleistung CA: 450A
Maximale Entladeschlussspannung: 10,0V
Temperatur-Einsatzbereich: -10°C bis +60°C
Temperatur-Lagerbereich: -40°C bis +60°C
Ladestrom standard: 7,5A /1C /~ 60 min
Ladestrom maximal: 30,0A /4C /~ 15 min
Anschluss: gängiger SAE-Kfz Polanschluss / Polanordnung wählbar
Baumaße: L 215 x B 180 x H 125 mm (inkl. Pole)
Baumaße: L 243 x B 175 x H 125 mm (inkl. Pole)
Baumaße: L 279 x B 175 x H 125 mm (inkl. Pole)
Baumaße: L 311 x B 175 x H 125 mm (inkl. Pole)
Empfehlung:2 - 4 Zylinder Motoren von 1,0 bis 2,0 Ltr.
That’s a nice looking battery. Like you say I’m surprised special charging is required when it will be charged by the car system the same as the oem battery. I’m sure the charger we have has different modes for the type of battery and it’s nothing special?
On VAG you can choose a li-ion battery in the 'OBD dealer system' or 'techstream' equivalent, wonder if that is the case here too?
I run lithium batteries on all my motorcycles and they are still carburettored so they have zero technology in them.
Ran for 3 years now and no issues. I have an alternative plug in trickle charger / battery saver but I only use that if I flatten the battery.
I think you need a different charger to trickle charge/recover a battery but the charge an alternator gives is acceptable.
Also lithium batteries appear to maintain stronger voltage longer but then drop off a cliff when lose power. So for me lithium batteries are superior in terms of cranking and storage on the bikes, plus the weight bonus 3800g vs 800g and the size. Only thing that puts me off a lithium in a car is price
Asked CS batteries best battery choice for daily driven GR Yaris and they recommended this. It's 1kg heavier than their motorsport option but is propably better off for daily usage, and quite light still (3.6kg).
Great, only 530€ with charger.
Two things.
- Sometimes car isn't used for weeks, will need to measure 'sleep' current to get an idea if I want to go ahead. Switching off keyless in car perhaps...
- Do they have a small version, want to create some extra luggage room...
Two things.
They do have motorsport version but they recommended this for daily use as it seems to be more robust.
THe lighter version is the one I linked earlier in the same thread. seems to be 5cm lower.
I'd prefer using the mobile kill switch as it could be controlled remotely.
Larger 3.6kg version Dimensions (WxDxH): 279 x 175 x 189 mm
Motorsport 2.6kg version dimensions (WxDxH): 279 x 175 x 125 mm (inkl. Pole)
Asked from service team and they said using LiFePo would not need any coding from the GRY as such. They said it's good to be used, of course it voids battery varranty (as not original Toyota Part) but wouldn't affect anything else. Great stuff.
Yeah Toyota told me the same, only voids battery itself warranty if using these. So I bought the Touge Deadweight 500 and it's great, only issue I've had was caused by my stoopid Blackvue dashcam which doesn't have voltage profiles for lithium batteries (I asked Blackvue about firmware updates but was told "it would need a completely different battery monitoring technology" which sounds like BS to me, so I've had to disable Parking Mode instead 🙄)
Wonder if these weight savings apply to GR Y ? :unsure:
Going for 3.6kg 20Ah LiFePo4. Noticed that CS batteries don't deliver to Scandinavia but found a Estonian Vendor who seems to have fair service.
Adding BT battery monitor (such as this) and ordering a good charger if needed - lets see how "fast" the sleeping GR will drain it's battery.
I'll keep the stock battery as reserve, maybe to use during coldest months (Dec-Feb).. or maybe not.
Probably more as you reduce the weight by a greater percentage (assuming most vehicles are 1400kg).
Although the car will self weight reduce from rust by the time you get to this mileage 🤣😂 Or so the forums would have you believe
Finically it’s not worth, but car ownership is a mattter of the heart not the head
So approx 0.075 cents per KM. Perhaps not the best argument for a new battery considering the cost of the battery. Smiles per mile might be better.;)
Yesh the GR Yaris application for me seem to be enjoying the torque and nice chassis so removing weight should make it better (although removing it from rear will change the car dynamics abit). Haven't tested of rear seat removal yet but was thinking it could be my 'performance gains' for next summer - taking rear seat out occasionally and having 50kg lighter car should have an effect on how it goes..
Installed the BT battery monitor - so far battery looks to be ok and it is readable from our toddlers room (next to garage) so no need to go next to car!
Read somewhere that LiFePo4 wouldnt charge well under sun zero temps so most likely need to use regular battery during winter.. Especially as battery is in trunk so it doesnt get engine heat
