GF-6A or API SP RC are formulated to prevent LSPI. 300V is a classic but not sure it fits this kind of latest gen engine....
Engine is designed for hard use on 0W20, it is better to install an additional oil cooler if oil temps get too high, then to mess around with alternative viscosities...
@MagnusT uses Millers last time we talked and probably has most track miles in Sweden, also speak to @DrSetup who is running higher power and already a Time Attack champion in his class. Link
Yeah that's new that they recommend it 'especially for ethanol'. And if it is LSPI approved as @Tralien says,I see no big issues. Assuming that base is covered, then the Power 0W30 makes sense to me too.Ok, yeah, I just want the "best" oilAssuming that the original oil is not really "track oil"
But Motul 300v has a new version for 2022. Should be up to spec for new engines one would think.
Interesting. I did not know that.300v can be used, but only use the new one with carbon look that sais lspi protection support on the side of the can. the old silver one is not lspi proven, so no api sp standard.
but as toyota uses fully synthetic oil, I wouldnt change to mineral based oils like 300v
OE oil not really, but the OE spec Millers EE Performance is especially formulated by Millers for track use iirc.Ok, yeah, I just want the "best" oilAssuming that the original oil is not really "track oil"
Is mineral the 'The Organic base using non-fossil renewable materials' referenced in tech data sheet? Don't many ILSAC GF-6A oils have some mineral base (despite being called fully synthetic?)? I haven't understood this as there are some many conflicting opinions on the matter...but as toyota uses fully synthetic oil, I wouldnt change to mineral based oils like 300v
