GR Yaris Panel Air Filters
MrJ
Administrator
Staff member
So, what advantages are there of swapping out the standard air filter element for an aftermarket one?
There are quite a few manufacturers out there with their own replacement elements (Pipercross, ITG, HKS, etc), so what is the selling point? Is it higher airflow, and is it likely at the cost of poorer filtration? It sounds like they did a good job with developing a new type of standard filter element for the GRY so struggling to see the advantage.
I had an HKS Super Air Filter bundled in with my HKS exhaust, and am wondering if there any point fitting it, though I'm leaning towards just chucking it on Ebay rather than opening it and trying it out.
For some the advantage in the old days was that you could wash it and reuse it.
I thought it was pretty much proven these days on a dyno that a panel filter in the OEM airbox didnt add anything. It could even be worse if you got oil from the filter on a MAF etc.
Ok thats all generic info, but i believe from what ive read on the GRY forums that uprating our filter isnt any help at all especially without any other mods,.
Reactions: MrJ
That's the impression I've had too. I'd always pop a K&N or ITG on my SU carburettor on my old Mini, but that's a whole different era. Seems to me that unless you're changing the entire intake, there's no advantage to just the element itself, other than leaving yourself open to extra wear and tear on the engine if the filtration is poorer?
I'd take no performance benefits but extra whooshy noises, as long as the filtration wasn't worse.
P.S. Anyone want to buy an HKS Super Air Filter? I hear they are a cheap way of getting a big performance boost 🤭
@DeanoC fitted an itg? I’m sure it was but found it wasn’t filtering the best. Did you return to standard deano?
Unless you MUST have a washable filter, stick with stock.
@Phil1291 tested a HKS iirc and it gave lower power and from their own documentation, filtering is like 5x worse.
Independent german test showed that all aftermarket filter have worse filtering then OEM. Causing additional engine wear.
You can't see the aftermarket filter.
Oiled filters can foul the MAF sensor.
GR Yaris press there was a text stating they made special efforts to make the OE filter flow extra well with a better material (red material instead of normal white paper)
Stay stock and if you wanna throw money at it, change the stock filter sooner so there is less restriction from dirt.
If I wanted washable, I would do my research and try to find independant tests for flow and filtering.
Yeah I remember watching that video, and I've come to the same conclusion.
I can't help but wonder why there is a market for them, and I've seen many cars where one of the first things the owner has done is swap in an aftermarket filter. Force of habit perhaps?
With the air filter being the gateway to the engine, surely it opening up a whole world of potential warranty issues relating to wear on the engine?
guess quite few fit aftermarket in the belief there's a power increase and zero care of the extra engine wear as will sell after couple years anyway
Turbo noises wastegate chatter sookin like a dyson
