Nice, I may go 0w20 during cold winter months. I current run 0w30 for summer.Ready for service in 4 weeks time.
Mine is being locked away soon so no running over the winter.Nice, I may go 0w20 during cold winter months. I current run 0w30 for summer.
I too may tuck GR away during any bad winter months.... As long as oil meets API SP and is high quality then either 0w20 or 5w30 is ok in the U.K.Mine is being locked away soon so no running over the winter.
I’m sticking with the 0w20 for the time being.
There wont be any recommended 40 weight oil… I recommend going Mobil 1 ESP 5W-30, it is a very thick 30 weight, so may consider it as a 40 weight oil. It hold viscosity pretty well and you should be fine with that especially if you run oil cooler.Hey guys,
Anyone here who tracks (or not) the car, using 5w40 grade oil? Looking to step up the game for next season. Car is DD + pushed on track, I do have oil cooler.
Was thinking Ravenol, but their recommendation ends at 5w30 to our cars, page is not showing any results for 5w40 products.
here's my latest result of used oil analysisHere is a follow up to my oil analysis experiments... While 1 oil analysis won't tell you the whole story, it is clear that the wear stabilised.
Key takeaway here is, how the FA24 is harsh on the oil, look how much the oil sheared down in just 3k road miles. This is the main reason why I won't run xW-20 oil in my car anymore... even during shortened oil change interval, your oil could shear down to dangerously low levels. I know it takes double flush to get all the old oil out of the engine, so the low viscosity is partly caused by the leftovers of 20 weight oil in the pan/engine. Also I haven't experienced noticeable oil consumption on the 5W-30, which couldn't really be said about the 20 weight oil.
Sample: Motul 8100 Eco-Lite 5W-30
Type of use: No track days, spirited driving, autobahn runs, mountain runs.
3168 mi / 5100 km on oil
6151 mi / 9900 km on car
Translation of the subjective interpretation of the technician: "increased silicon content indicates a possible dust leak into the oil. Reduced oil viscosity (possible fuel leak into the oil). The values of the other measured parameters are normal. We recommend changing the filter and checking at a reduced interval."
Oil change just shy of 50,000. Picked up a Millers oil testing kit and sent away - been running Mobil 1 ESP 5w30 as @unrealpatrik above. Circa 5k miles on the oil, mix of hard Nurburgring laps, loooong European motorway journeys, and regular commuting /hard driving back home. As above, viscosity @100C holding rock solid in range. However, I've since swapped to Valvoline Restore and Protect 5w30 as pricing was better.
Some elements removed for privacy. High boron as its an additive in the Mobil 1 oil. The big tick is very nice
