GR86 GR86 - The clutch pedal thread
Does anyone know if a M-TEC Clutch spring actually helps? Thinking about it after a year of daily driving in heavy Traffic.
Night and day difference for me. I have no issues at all now, I didn't use the mtec spring I bought mine from Lee Springs as it was significantly cheaper (although unfortunately there is a minimum order/spend from what I remember).
This is normal. Had it on the first gen to, caused by the still spinning input shaft being stopped by the synchro as you mesh the gear.
If you hold the clutch and leave a few seconds, and then engage first, it probably wont happen as the input shaft will have slowed down, nothing to worry about.
Yes I tested this.
Never noticed it before, but I usually drive old stuff, the knackered input shaft bearings probably mean it spins down faster.
That is good to know because initially I thought I had adjusted the clutch bite point too close to the firewall! :D
So I had my clutch spring sat in the packet for many months now and of course it's the perfect time to fit it between Christmas and New Year, slobbing around eating too many sausage rolls so thought it was best to start challenging my flexibility, and boy did I.
I had actually got used to how the clutch felt, but did wonder how much of an improvement it would actually make so I went for it and thought i'd add my 2p here for those on the fence.
Agree with most of what I've seen in this thread , however for those who might have felt like they've got used to it and not that fussed, I get it, i do. The first 10-15 mins out i thought 'meh, its different, bit weird feeling but cant see it being better.' Was cursing the fact i'd cut my fingers and given myself a wonky posture for not much gain here.
...Then i pressed on a bit, tried a few fast gear changes, a launch from 1st to 2nd, a few heel-toes (best effort..) , and it is definitely better. There is less lurch, less guessing , despite me previously being completely used to the car (23k miles!).
Overall glad ive fitted it, wouldnt suggest I can feel more, but the main thing for me is that its stopped pinging the pedal back at that bite point which created some uncertainty. Now its just one less thing to think about.
Hope this helps anyone in the same shoes as me
Abracadabra I got GKTech pedal spring kit. Love it.
Here’ video of why and how I fitted lightest 66% lighter one:
^ If anyone wants a free GKTech 33% lighter Clutch Pedal Spring then DM message me ^
* See above video on DIY fitment is not too mad. I fitted 66% lighter spring and loved it.
**** UPDATE EDIT **** GONE. On way to NEW owner now. Who Hopefully comments when fits. Enjoy!
^ Sorry to hear that my spare spring give away didn’t workout. The half torn normal, post office had no padded envelopes, ordinary envelope arrived did but the spring was no longer inside for @GRimzy Sorry man.
Definitely worth getting and fitting 👍
They arrived today :-)
On order should arrive sometime this week. Will also change the bite point on clutch way to high
Afternoon
Can't remember my GT86 being like this but after nearly 2 years of owning the GR the low speed clutch bite point is starting to make me not enjoy the car even after getting used to it after a few months into ownership and being able to rev match/heel toe. I'm not practical in the slightest lol so asked my local stealer and they've advised you can't alter the clutch which i know isn't true :ROFLMAO:
Any advice on this please?
Main dealer will not touch this. Do you know a good Indy garage?
Thanks for the clarification, i'm in the West Midlands so will have a look! Have you changed yours btw? and if so how many turns (if that's the correct term)👍
Yes, first thing I did in fact, which says it all.
Don’t get hung up on how many turns it’s very much a personal preference, I found closer alignment to where the brake pedal is worked for me. Be careful not to go too low as it won’t feel right and you risk not disengaging the clutch completely.
