Gave the bay a detailing ready for a new intake tomorrow. Left Lanoguard around the struts and firewall for protection.
In other good news after swapping the PCV valve for a fresh one and putting on a few hundred miles the car hasn't touched a drop of oil. Fingers crossed.
Local dealer couldn't work out the part number. Ordered a couple from TEQsport in the US.
I'm still waiting for the dealer to even phone me back. I'll see if I have the right ball attachment for a 22mm socket when I get home and if I do I'll do it myself. I have a Subaru dealer in my village and the Subaru part number comes back for several Subaru's so may try them.
I'm only in Pembs if you want a hand, happy to drive up. I got all the attachments and sockets to do it.
And my dealership said they would find out the part number and call me back. They never did.
Reactions: KobayashiMaru86
Subaru dealer was very helpful. Gave him the part number along with a reg from an imported BRZ from here to cross reference. £14 and I'll pick it up Saturday. If I need a hand I'll let you know. Happy to spin to yours.
Reactions: Bobocop
Cool. I'm off work Sunday and Monday so hit me with a message if you need a hand.
Excuse the lack of eloquence but three (or four?) words: big f***off intake.
When I did my own I was minded to put the 'spare' OEM bolt & rubber washer back into the hole adjacent to the Coolant reservoir rather than leave them in a box - at least you know where everything is come reversal time. Mentioned it because I note the vacant hole in the above photo. Mine is fitted with a plastic cap which is why it looks different in the screen shot below btw ... ;)
Reactions: Bobocop and guysat
Got on the Eurotunnel first thing this morning and got bumped up two slots so pretty much drove straight on which was ideal. Then 433 miles through France, Belgium, Luxembourg and Germany to arrive at Sinsheim to spend tomorrow at the Technik Museum, thanks @RedCarsGoFaster for the information you posted about this last year. 👍🏼
Wtf.
£33 from Toyota. I've asked them to order one but I think I'd rather wait a month and get it from Amaya a for 6 quid. I would try Subaru but the nearest dealer is an hour away.
Wtf.
I picked up two Toyota PCV valves from TEQSPORT in the US for $40.49 posted.
I was debating it but I have what is essentially a crate of OEM bits their own marked bags and boxes :)
I disconnected the battery when fitting. After driving a few hours the car definitely sounds a little throatier, throttle response is a tiny bit sharper and there's more grunt around 3k rpm and at the top end. Not entirely convinced it was worth the financial cost but it is a noticeable upgrade for sure.
Reactions: AEG86
Make sure you don't miss the motorbikes - some really rare and bizarre stuff
Reactions: AWB
Had the tyres swapped out for the stock Michelin Pilot Sport 4s after having CrossClimate 2s on for the last year and a half, also got a wheel alignment done too. Might as well use them while I can until winter kicks in again (living in Scotland this could be August for all we know) before putting the all seasons back on. Forgot how grippy the car is. Dare I try to extend the G meter a little closer to where my car's previous owner had it? Probably not but a man can dream.
Reactions: AWB and Bobocop
Had a free day today so decided to get the car in the air to fit the Endless MX72 brake pads that I bought last year, but then held off fitting thinking that perhaps there was still life left in the original pads. Turns out I could probably have held off even longer...
...that's 25k miles of road only use. Barely a couple of mm worn compared to the new ones. So if anyone's thinking of changing theirs at about the same mileage, you can probably save your money :D
I'd always planned on upgrading the pads anyway, so I still went ahead and changed them. Hopefully once they're bedded in, they will be noticeably better enough to justify the change. At least they are still ridiculously easy to swap.
I had a couple of other jobs to do too with all the wheels off. Wanted to clean and degrease all the suspension components with a view to also giving them some rust protection, and rotate the tyres. However I finished up an hour ago and the Amazon delivery of the Waxoil aerosol I ordered isn't due for a while. Wanted to get the wheels back on, so sod it, that can wait until another day.
Also, wanted to go give my wheel arch liners a scrub. I'm not generally bothered about that level of automotive detailing; but ages ago I must have driven over some white paint as I had loads of it spattered inside the liners, and I kept seeing it. Ended up using a pan scourer to get it off.
At least I also took the opportunity to give the wheels a good clean and tyre gelling. Now I have sparkly clean wheels on a dirty car.
Edit: Amazon driver turned up about an hour ago with the Waxoil. Decided I didn't want to leave the job half done, so went and jacked the car up again and doused all the suspension arms and dampers.
Covered 773 miles on Friday night / Saturday morning to meet the better half in Belgrade (she had been working there for a couple days).
Yesterday we travelled to Banjia Basta in the south west to kayak on the Drina river. The road from Valjevo was exactly what the 86 is designed for with lots of corners and hairpins. The back end stepped out a couple times without prompting. I explained to Mrs AWB this was due to her suitcase in the boot acting as a pendulum! The next couple however were prompted by me and even Mrs AWB enjoyed the brief moments sideways!
Slightly surprised by the positive reaction I enquired further and she advised it’s the fact it didn’t involve a lot of speed (good to know for the future!😉).
The fact big speed isn’t required and the car’s innate playful nature really is what makes it so enjoyable to drive/own.
Be safe out there and keep it Shiny Side Up!
Reactions: AWB
