Peak boost with my ecutek tune was only raised 1-2 psi, the top end gains are from not bleeding boost off as rapidly as stock. Fuel and ignition timing is also adjusted. Noticeable torque increase.can anyone post some dyno sheets before / after with tuned stock ecu?
im going down this road this summer, but i dont want to tune for numbers, i want some decent torque upgrade from 2000 rpm and a flat curve. peak torque even could be the same, that´s not my target....+ some more power at higher rpm....so could this be achieved with stock ecu? or is it just the boost that is ajusted with stock ecu mapping? so we get a "parallel displacement" with some more NM ?
Can you choose when tuning stock ecu? Do they adjust fuel + ignition or just boost?
