GR Yaris Airtec enclosed intake
Bronson
Isle of Man
I haven't found many posts of people running this...
https://www.airtecmotorsport.com/product/airtec-motorsport-enclosed-cais-for-toyota-yaris-gr/
No info at all on temperatures just the usual BHP nonsense.
It's half the price of an Eventuri/Sprint but it's still £600
Cone filter could/should improve noise but possibly at the expense of filtration quality?
I can't make out what's going on with the inlet duct, does it have a flap or not?
I like the fact it appears small but with a seemingly bigger inlet and it's enclosed so warding heat-soak should be better.
I would also love to hear if anyone has fitted one of these and there thoughts on it ??
https://www.airtecmotorsport.com/pr...closed-carbon-fibre-cais-for-toyota-yaris-gr/
Airtec are now doing the same thing with a carbon fibre enclosure. The original did very well in the Tegiwa test for power and intake temps (taken with a massive pinch of salt). This has been my favourite of all the intakes on the market but I still haven't bit the bullet on it...the fact it's now available with a bit more engine bling is interesting...
What they probably realised was that the standard open cone filter kit they were (and still are) knocking out for £300,suffers from massive heat soak in the engine bay
Hence now put in a box and double the price.
Hi, anyone who uses this CAIS and could share their opinion? Is it a valid alternative to the Eventuri? Thanks
Been running one since spring last year. Intakes don't make much real world power on this platform (under most conditions). Just buy what you can afford and makes the best whooshy sounds you enjoy.
We offer/sell the Airtec, ITG and Airtec Eventuri products. - The first consideration when purchasing any induction kit is the MAF housing.
The GR Yaris is quite ‘old school’ in the fact that it still uses a MAF sensor senor to measure airflow speed. The majority of other manufactures now use muti MAP sensors on the induction system to calculate airflow.
Consequently, the internal diameter of the MAF housing is critical to allow the ECU to accurately interpret the airflow data it receives from the sensor and to allow it to set the correct fuelling/boost etc
If the internal diameter is bigger the measured airflow passing through the housing is slower and the ECU will have to make corrections to compensate. Again, if the internal diameter of the housing is smaller the airflow passing through the housing will be faster and again the ECU will have to make corrections to compensate.
When we started the tuning process on the GR Yaris, we accurately measured the OE MAF housing. We also noticed that the OE housing featured a triangular protrusion which we assume helps stabilises airflow.
We then measured the induction kits available at that time and soon discovered that the only one with a MAF housing anywhere near the OE housing was the Eventuri – hense why we chose that kit for our software development.
As the years have passed other induction kits suppliers have improved/updated their MAF housing designs to match the OE dimensions.
During 2026 ITG launched their Gen 2 carbon induction kit. This is the 1st kit available that 100% replicates the OE housing including the triangular protrusion.
The next consideration is the position & size of the filter itself. – On the open filter designs we have see if the filter is too close to the MAF sensor/housing we have seen airflow readings fluctuations at certain load/rpm points caused by turbulence caused by the filter design. Ideally there needs to a space between the filter itself and the MAF sensor on the open filter designs . Also if the filter surface area is too small this can also create problems
As a tuning company we also prefer to use enclosed induction kits to help keep the inlet temps down.
Finally, one thing we have learnt with the GR Yaris is that it is exceptionally tolerant of incorrectly sized MAF housings and even with the worse one will run reasonably ok and not create any EML lights etc – Its only in the ECU data that you can see it making corrections to compensate (reduced boost etc) – other cars that we work on Ford ST/RS would just simply go into limp mode or bring on the EML on the 1st time you try and accelerate.
Yes, we've seen lots of anecdotal evidence of this over the years; people with induction kits that work...most of the time, but which throw the odd error or CEL. Chasing out those issues seems to be tricky, maybe party because the ECU is obscuring the true severity of the problem 99.99% of the time.
It is puzzling/disappointing that Toyota didn't go the MAP route with the Yaris. Maybe next time!
Helps to know that air flowing directly through the MAF is measured. Anything flowing under and pass the sides of the sensor is not measured but calculated so changing the diameter usually causes issues.
Hard to believe the Toyota (Denso) ECU is tolerant of anything. Only have to fart in the car and it's "Visit your Dealer" message :rolleyes:
